    Plugin Licensing issues in Sketchup 2017
    14 Posts 4 Posters 872 Views 4 Watching
    • B
      Brassovitski
      After installing Sketchucation Store Extension v 4.2.9, I'm having trouble activating my License for Fredo 6 "Fredo Corner". I am attaching a document with various screen prints.
      Can anyone help with tips on what to do?
      Licens problems Sketchup 2017.pdf
        The .scflicense does reside in the License folder
        Use the Tools > Fredo Collection > Fredo Corner > License menu to open the dialog. Then validate by 'opening' the .scflicense via that dialog
        • B
          Brassovitski
          Hi Rich
          I have done as you write, but get an error message, see the attached screen print. How do I proceed?
          Sincerely
          • fredo6F
            fredo6
            The license registered has been purchased in April 2021 (18 months ago) and is already validated on one computer.
            Are you trying to validate on the same computer or another one?
            • B
              Brassovitski
              I think I got 2 different versions mixed up. See attached document. Can you tell me which one I paid for? What is the difference between the 2 versions?
              It's the same computer I'm having trouble getting the license to work, I think I may have updated to a wrong version of the plugin.
              Sincerely
              Fredo Round corner 2 versions.pdf
              • fredo6F
                fredo6
                You purchased a license for FredoCorner (not RoundCorner).
                • B
                  Brassovitski
                  How do I go about getting the program licensed?
                  I now have FredoLib 13.6a and FredoCorner 2.5a installed, but still get the same error message when I try to activate the license?
                  • B
                    Brassovitski
                    I would really appreciate some help to make it work, I have a 3D printing project I would really like to have the drawing ready for.
                      The best thing you can do is a fresh plugins folder. Based on your earlier PDF stuff you've a bit of a mess going on somewhere.
                      FredoCorner works fine but your system may be muddled and there's likely a conflict at play.
                      • B
                        Brassovitski
                        Hi Rich
                        I think I now have reasonably good control over where I store plugins. See attachment, please.
                        I think the problem occurred when I was prompted to update FredoCorner and I installed RoundCorner instead, but that should be cleared up now, but I still can't activate the license for FredoCorner. If I was just sure it would fix the problem, I'd buy a new license, but it's a bit of a waste if it still doesn't work!
                        This here is my default plugin path.pdf
                          Go to...
                          C;\Users\SomeName\AppData\Local\SCF Licenses
                          ...and delete this
                          https://i.imgur.com/jKpejHt.png
                          Restart SketchUp and try to validate FredoCorner with the license file at https://sketchucation.com/webshop/my-licences.php
                          • TIGT
                            Your extensions/plugins should all be installed in the ...AppData/...Plugins/ folder path.
                            Sketchup would install them there by default - as should the SketchUcation ExtensionStore³.
                            If you have bought suitable licenses you should be able to validate them for the appropriate extensions in their sub-menus [usually under the Tools menu]...
                            As Rich explained you can reset your licenses using the path he provided...
                            • B
                              Brassovitski
                              Hi Rich
                              I cannot say how grateful I am for your guidance. Now I finally managed to get the plugin licensed again. Thanks a million for the help. I am super happy that there is always someone here in the forum who takes the time to help the rest of us who do not have the necessary knowledge to solve the problems that occasionally arise.
                              A very Merry Christmas to everyone who has contributed to this thread.
                                @brassovitski said:
                                I cannot say how grateful I am for your guidance....
                                ...A very Merry Christmas to everyone who has contributed to this thread.
                                You did the heavy lifting so thank you for supporting independent plugin developers by purchasing a license.
                                Enjoy the xmas and new year 👍
