    Corner bricks render
    15 Posts 7 Posters 2.0k Views 7 Watching
    • L
      Hi, I was walking in an area I do not usually visit. I saw a renovation had been done to an old Australian Federation style house with a childs toy in the front of the new build. I thought it would be an interesting subject to render render.
      In those days we did not often get perfect vitrification of clay bricks. when I did a test render the bricks looked fine but the corner, the bricks did not look convincing (a perfectly straight edge) I took a lot of "chips" out of the corner, it took quite a while but it did the trick. ๐Ÿ˜„
      • HornOxxH
        HornOxx
        ๐Ÿ‘ what a beautiful "snapshot" this is! - precisely because of its scenic "randomness"...
        never trust a skinny cook
        • L
          @hornoxx said:
          :thumb: what a beautiful "snapshot" this is! - precisely because of its scenic "randomness"...
          Thanks Horoxx ๐Ÿ‘ that is what i thought. Did the owners run out of money, were they exausted having a small child and doing a renovation? Is Mum or Dad working super hard to pay for it? Why is they child playing in builders spoils? Thats why I was interested in that situation, it is a story.
          • Bryan KB
            Perfect! ๐Ÿ‘
            • tuna1957T
              tuna1957
              ๐Ÿ‘
              • marked001M
                marked001
                very cool detail
                http://www.revision21vis.com
                instagram: revi21on
                • L
                  As per my usual neurosis, I did some moor work on the original image. I think the last bit is the bit where I learn the most.
                  • ntxdaveN
                    ntxdave
                    Good improvements IMO. Sharper and brighter, to me. Very realistic IMO. ๐Ÿ‘ ๐Ÿ‘ ๐Ÿ‘
                    Press F1...thank me later
                    • Bryan KB
                      Wow! It was perfect to start and yet you made it better!
                      Outstanding! ๐Ÿ‘
                      • locoL
                        loco
                        Nice job, very well done. You have an eye for detail, especially in the work you put into the corner ๐Ÿ‘ How about using Round Corner to correct the sharp edges, I use this myself sometimes.
                        Windows 10, gpu rtx 3060 12gb ram, cpu AMD Ryzen 5 5600X 64gb ram, SketchUp 2022, Twinmotion 2022. My Little Tutorial
                        • L
                          Thanks nxtdave, Loco and Bryan ๐Ÿ‘ I find it worthwhile to sit on an image for a few days and then pic it to bits. It seems those tweaks can effect the overall look very positively. I was suprised at the difference, as I usually am ๐Ÿ˜‰
                          About round corners, I could be wrong but not sure I would have control over the brick coursing with round corners and I got the "Craggey" look I wanted. I will give it a try though ๐Ÿ‘
                          • L
                            Never let a photoshop newbie (me) do post production on a render. On advice the image was too sharp I think this one is the best image
                            • locoL
                              loco
                              You will still have control over the brick material in TM.
                              • L
                                Hey Loco, Can you clarify please?
                                • locoL
                                  loco
                                  You can scale it and position as you want on each face separately if need be. So you can fine tune it.
