    Corner bricks render
    15 Posts 7 Posters 1.9k Views 7 Watching
    • Bryan KB Offline
      Perfect! ๐Ÿ‘
      • tuna1957T Offline
        tuna1957
        ๐Ÿ‘
        • marked001M Offline
          marked001
          very cool detail
          http://www.revision21vis.com
          instagram: revi21on
            As per my usual neurosis, I did some moor work on the original image. I think the last bit is the bit where I learn the most.
            • ntxdaveN Offline
              ntxdave
              Good improvements IMO. Sharper and brighter, to me. Very realistic IMO. ๐Ÿ‘ ๐Ÿ‘ ๐Ÿ‘
              Press F1...thank me later
              • Bryan KB Offline
                Wow! It was perfect to start and yet you made it better!
                Outstanding! ๐Ÿ‘
                • locoL Offline
                  loco
                  Nice job, very well done. You have an eye for detail, especially in the work you put into the corner ๐Ÿ‘ How about using Round Corner to correct the sharp edges, I use this myself sometimes.
                  Windows 10, gpu rtx 3060 12gb ram, cpu AMD Ryzen 5 5600X 64gb ram, SketchUp 2022, Twinmotion 2022. My Little Tutorial
                    Thanks nxtdave, Loco and Bryan ๐Ÿ‘ I find it worthwhile to sit on an image for a few days and then pic it to bits. It seems those tweaks can effect the overall look very positively. I was suprised at the difference, as I usually am ๐Ÿ˜‰
                    About round corners, I could be wrong but not sure I would have control over the brick coursing with round corners and I got the "Craggey" look I wanted. I will give it a try though ๐Ÿ‘
                      Never let a photoshop newbie (me) do post production on a render. On advice the image was too sharp I think this one is the best image
                      • locoL Offline
                        loco
                        You will still have control over the brick material in TM.
                          Hey Loco, Can you clarify please?
                          • locoL Offline
                            loco
                            You can scale it and position as you want on each face separately if need be. So you can fine tune it.
