    House
    12 Posts 5 Posters 1.5k Views 5 Watching
    • Gus RG Offline
      Gus R
      A Thea Render of a house I modeled for an NPR rendering back in 2008.
      Update:
      Found a brick generator from Poligon called Bricks Modern Generator ($35 USD) which uses Adobe Substance Player which if free and available from Adobe. They have other generators for different materials like cloth or flooring. You can save a preset for a typical type of brick you use and change a variety of parameters including color and a color picker that works outside Substance Player's window and on a picture you have open or anything open in your browser.
      You create the bricks in the Substance player using the Poligon SBSAR and then click export to bitmaps where you save to a directory. Then in my case you create materials with Thea Render from bitmaps and the directory where they're located.
      So here's a painted white brick version and a rusticated red brick look.
      www.instagram.com/gusrobatto/
      www.facebook.com/gusrobatto
      • Bryan KB Offline
        Wow! Very nice! πŸ‘
          Magic. πŸ‘Š πŸ˜„
          • ntxdaveN Offline
            ntxdave
            Very nice! πŸ‘ πŸ‘
            Press F1...thank me later
              Very nice work Gus, By the look of the landscape you are not a lazy modeller πŸ˜‰
              • Gus RG Offline
                Gus R
                Thanks all. Most of the landscaping is from Vizpark. The grass is Skatter. I modeled that way back and found a lot of ungrouped geometry. I did all of the modeling by hand for the house.
                Here's another one including a work view and the old NPR rendering.
                If anyone has any questions feel free to ask.
                • Gus RG Offline
                  Gus R
                  Thanks. I've dabbled with landscaping plans which mostly involved industrial site plans. Doing it with proxies is a little difficult because all I'm looking at are wire frame boxes before rendering.
                    Hi Gus, I meant the topography is not a flat plane. Complex topography much more work but so absolutely worth it πŸ‘
                    • Gus RG Offline
                      Gus R
                      Oh. In this one I just did a simple downward arc from the front setback to the back of curve. A previous rendering I used Fredo's topo generator and was lucky enough to have the topography from the land survey in CAD.
                      I did the Grand Tetons back in 2013 using topography from a USGS PDF which I converted to lines in some program I was using back then. It was quite tedious but I seemed to enjoy doing it.
                      • ntxdaveN Offline
                        ntxdave
                        Minor correction; the name of the plugin is TopoShaper. πŸ˜„
                        • Gus RG Offline
                          Gus R
                          Right? It even says so in the link to my original post. πŸ˜„
                          • ntxdaveN Offline
                            ntxdave
                            My apology! I did not go to your link. I just read the text. If you look in my direction you should see a ver bright red glow from my face. Maybe it is time for me to take a major break from posting.
                            Again, My APOLOGY !
