    Normals map generator
    6 Posts 3 Posters 5.9k Views 3 Watching
    • L
      I have never created my own normals maps and the thought or creating then intimidated me. This generator looks like it is worth a look https://cpetry.github.io/NormalMap-Online/
      • tuna1957T
        tuna1957
        L i am , F.Y.I. you can also create normal maps in Gimp. Watched a few tutorials and it seems to do a good job for me. 👍
          Just be aware of the normal format these export to. OpenGL and DirectX normals Green channel are opposite. So if you see stuff raised at render time that should be indented its usually the normal map.
          • L
            I feel sick now 😕
            • tuna1957T
              tuna1957
              Rich is correct about this. The Gimp tutorials I watched showed how to correct the map if it looks “inside out” as Rich mentions. I’ve had good results with using these Gimp created maps in Twilight Render…
                @l i am said:
                I feel sick now 😕
                It reads harder than it is to fix. Majority of archviz engines use openGL format. Just something to be aware of.
