    Cannot insert an clip in animator what is longer 4sec.
    Scheduled Pinned Locked Moved Animator Beta
    renderpluginsextensions
    3 Posts 2 Posters 2.7k Views 2 Watching
    • K Offline
      keck
      Ciao bella animator fredo6 community. Crazy day today; since some hours today I cannot even more insert an clip whitch is more than 4 sec into the timeline within animator fredo6. I dont know what I have done? certanly my fall; but I now already play some hourse to fix it; but without success. Would be grat to get an hint what was happen and what is to do to fix it. By the way; very very great tool this grandiose ANIMATOR FREDO6. Hope for help. AAhh some more info in this case. I have also the same software (Animator_v3.7a and LibFredo6_v12.9a) on a second PC and he has the same error. Saluti Rolf
      I can insert a clip into the timeline (10sec)
      But after open thr clip I can only use 4sec.
      • Rich O BrienR Online
        https://i.imgur.com/0P42DWs.png
        Use the white triangles to lengthen or shorten clips
        • K Offline
          keck
          Hi Rich; thanks for your hint. But it does not run like your suggest. The triangles cannot be moved. At least on my surface. They light up red yes; but cannot be moved. I suspect I have somewhere else unintentionally changed a parameter in the main settings. Because I have already created several animations with clips that do not have such a timeline bar because the length of the clip is selected via the "duration" function.
          ![on this picture you can see within the main timeline the clip called "erste palette"](/uploads/imported_attachments/oGPS_1.PNG "on this picture you can see within the main timeline the clip called "erste palette"")
          ![here you can see the opened clip "erste palette" there is not this white line with the triangles](/uploads/imported_attachments/HenH_2.PNG "here you can see the opened clip "erste palette" there is not this white line with the triangles")
