    Can't get Fredo6 CurviLoft to work
    extensions
    5 Posts 3 Posters 2.4k Views 3 Watching
      JALLAO
      I have purchased Fredo6 Curviloft and successfully loaded on my desktop. I have installed on my laptop but it is unresponsive to selection via icons or menu. Tried uninstall/reload validate license. Get the following error message.
      Error; #<NoMethodError; undefined method `visual_version' for SCFLicense;Module>
      c;/users/gbhan/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe;1733;in `tem_context'
      c;/users/gbhan/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe;1709;in `tem_launcher'
      c;/users/gbhan/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe;119;in `launch_action'
      c;/users/gbhan/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe;244;in `launch_action'
      c;/users/gbhan/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/fredo6_curviloft/bootstrap_curviloft.rbe;76;in `launch_action'
      c;/users/gbhan/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/fredo6_curviloft/bootstrap_curviloft.rbe;91;in `block in startup'
      c;/users/gbhan/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe;1460;in `call'
      c;/users/gbhan/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe;1460;in `command_invoke'
      c;/users/gbhan/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe;1441;in `block (2 levels) in build_config_commands'
      c;/users/gbhan/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/fredo6_!libfredo6/lib6traductor.rbe;1378;in `call'
      c;/users/gbhan/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/fredo6_!libfredo6/lib6traductor.rbe;1378;in `block in add_command'
      SketchUp;1;in `call'
      Any suggestions?
      Gerry
        Fredo will probably join in with some better detail...
        But...
        Have you installed the latest version of the SketchUcation toolset [+>v4.2.6] which contains the newest SCF-licensing code ?
        Have you installed the latest version of LibFredo ?
        Restart Sketchup to ensure everything is synced...
          JALLAO
          Yes. I've tried those suggestions without success.
          • fredo6F Offline
            fredo6
            The error you had comes from missing ExtensionStore or having a very old version of it.
            So, install the latest version of Sketchucation ExtensionStore.
            Then go to the menu Extensions > Sketchucation > SCFLicense: Global status... and check that in te dialog displayed, you have '5.6a - 50' displayed in the top left corner.
              JALLAO
              Thank you. I reinstalled Extension Store and problem corrected.
