    Texture Position
    11 Posts 2 Posters 8.1k Views 2 Watching
    • Gus RG Offline
      Gus R
      I suddenly have this model where I can't position textures within a particular group using the up-down/left-right arrows on the keyboard. Using the mouse works. This only happens on the red plane and not the green plane even outside the group. The texture is directly applied on the surface and not on the group. Anyone ever encounter this? This does not occur in other models.
      Uploaded part of the model. Still doesn't budge on the one side.
      Texture Position Test.skp
      www.instagram.com/gusrobatto/
      www.facebook.com/gusrobatto
        I've had it happen on .DAE imports sometimes. Strangely the offensive face/s that prevented texture positioning were non-planar quads that SU did not triangulate on import. So the quad was respected in SU even though SU doesn't support non-planar quads....but does when it feels like it πŸ˜•
        This non-planar quad UVs probably didn't jive with SU's UVW texture position but the importer still generated a non-planar textured quad in SU?
        So, yes I've had it happen but never on geometry that was created in SketchUp only imports.
        • Gus RG Offline
          Gus R
          Rich,
          OK. This model was generated with al native SU geometry short of using a CAD import of the floor plan which I've done hundreds of time before without encountering this glitch. It's even doing it within the attached model with new geometry composed of simple planes. I tried importing this model into a new SU file and it still doesn't work along the red plane.
            That is weird. First time I loaded file the checker texture would not move via arrow keys but other did.
            Then reloaded file and brick wouldn't move.
            Contact the pentagon....
            • Gus RG Offline
              Gus R
              Gremlins!
                Oh I see now. The face on the -x/+x plane don't move. Ok forget the pentagon, we need Elon for this.
                If you move the objects any distance arrow key movement returns. So your house must reside somewhere in Bermuda?
                  This fixed it for me...
                  https://i.imgur.com/0Sorxsk.png
                    https://i.imgur.com/wmVFddW.png
                    So its seems distance to world origin decides if the -x/+x faces can have texture positioning via arrow keys working or not. Which make sense if you think about it... 😳
                    Here I got positioning restored 50' from origin.
                      Yep, its reproducible for any geometry. Distance from 0,0,0 whether metric or imperial will kill arrow keys only on -x/+x plane.
                      https://i.imgur.com/9FHQM9F.png
                      I could move textures when at 20 - 25m then it stopped.
                      • Gus RG Offline
                        Gus R
                        That worked! I brought the entire model just short of the origin and everything is back to normal. Thanks Rich.
                          Its a nice feature not many people know about it. I call it SpaceX
