    Push/Pull a Rounded Edge?
    7 Posts 3 Posters 7.1k Views 3 Watching
      mgfranz
      Hi, I need help using the Push/Pull tool to extend a surface with a Rounded Corner. I have created the desired idea, but I would like to push the surface to .120". If you look at the attached, you can see I can round a flat plane, but how can I round the Pulled plane?
      Basically I need the .120 surface to look liked it was punched by a 10 ton press.
      SpikeStripSquare.skp
      SpikeStripRounded.skp
      "If you like what you do, it will never be work..."
      In memory of Sam Maloof, 1916-2009
        I'd use Joint Push/Pull.
          I can reload your files with the cool free Pcon Planner! πŸ˜„
          And export them as SU V 2017! 😎
          But better if you save directly as v6 to 2017 for avoid some acrobatic Reloads / Save as above! πŸ˜„
          And have a more large audience! β˜€
            mgfranz
            [attachment=0:3gkhruik]<!-- ia0 -->Screenshot - 5_30_2022 , 6_29_33 PM.png<!-- ia0 -->[/attachment:3gkhruik]
            Perfect! Great solution! Well worth the $12
              mgfranz
              [attachment=0:3cay6zg3]<!-- ia0 -->Screenshot - 5_30_2022 , 6_29_33 PM.png<!-- ia0 -->[/attachment:3cay6zg3]
              So Dave, I've been trying to figure out the tools of Joint Push Pull, do you recall the steps you used to create your result?
                I didn't remember so I had to download it again. I just called Joint Push/Pull, made sure it was set to thicken, clicked and released on the surface, moved the cursor, let go of the mouse, typed the thickness, pressed Enter.
                Click on the picture.
                  mgfranz
                  [attachment=1:3hfjd8zx]<!-- ia1 -->JPP.gif<!-- ia1 -->[/attachment:3hfjd8zx]
                  Yeah, that's kinda what I did. But it was easier to just pull from the bottom. Thanks for your help.
