    More Fredo6 plugins becoming paid extensions
    165 Posts 56 Posters 94.8k Views 56 Watching
      Try installing the latest version of the SketchUcation Toolset [v4.2.5] - publish recently...
      This has some tweaks to address issues with older MAC set ups...
        mavie
        You're the man, TIG. Thank you so much for this suggestion. It worked perfectly and Fredo's Collection of tools now work for me and are all validated.
          andtopri77
          Buenas tardes soy de Colombia, estoy interesado en adquirir el paquete de los 8 plugins y quisiera saber con respecto a los 3 asientos, a que se refiere?. gracias
          [mod=:1wgsf6mz]Good afternoon I am from Colombia, I am interested in acquiring the package of the 8 plugins and I would like to know with respect to the 3 seats, what do you mean?. Thank you[/mod:1wgsf6mz]
            3 dispositivos por licencia
              andtopri77
              Gracias por la respuesta, esto quiere decir que los puedo instalar en 3 equipos y trabajar con los plugins mismo tiempo ya que tengo un equipo de trabajo de 3 personas? o hay que estar quitando al licencia en uno para trabajar en otro. es es mi duda. gracias
                [mod=:3bcjsupr]Thanks for the answer, this means that I can install them on 3 computers and work with the plugins at the same time since I have a work team of 3 people? or you have to be taking away the license in one to work in another. it's my doubt. Thank you[/mod:3bcjsupr]
                Yes, you can use at same time
                SΓ­, puedes usarlo al mismo tiempo
                • chonC Offline
                  chon
                  Hello,
                  And you can desactivate a license on one computer and activate it on a fourth one... πŸ˜‰
                  Y puedes desactivar una licencia en una computadora y activarla en una cuarta...
                  SU2019 pro 19.3.253 + VRay 4.00.02 (Next) on Win10-64Bits
                  • Gus RG Offline
                    Gus R
                    I'm getting the following error when trying to install Fredo Corner.
                    This is from a regular install through Extensions Manager.
                    ` C:/Users/Z590-E/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/forwardable.rb:115: warning: already initialized constant Forwardable::VERSION
                    C:/Program Files/SketchUp/SketchUp 2022/Tools/RubyStdLib/forwardable/version.rb:3: warning: previous definition of VERSION was here
                    C:/Users/Z590-E/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/forwardable.rb:116: warning: already initialized constant Forwardable::FORWARDABLE_VERSION
                    C:/Program Files/SketchUp/SketchUp 2022/Tools/RubyStdLib/forwardable/version.rb:4: warning: previous definition of FORWARDABLE_VERSION was here
                    ***************ERROR LibFredo6 Menu **************
                    Sketchup = 22.0.354
                    Platform = x64-mswin64_140
                    title = Round
                    Ext =
                    @submenu =
                    @menu_name = FredoCorner
                    @su_menu_name =
                    C:/Users/Z590-E/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/set.rb:381: warning: already initialized constant Set
                    C:/Program Files/SketchUp/SketchUp 2022/Tools/RubyStdLib/set.rb:70: warning: previous definition of Set was here
                    File load error (C:/Users/Z590-E/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/set.rb):
                    Error: #<TypeError: superclass mismatch for class SortedSet>
                    C:/Users/Z590-E/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/set.rb:384:in <top (required)>'
                    www.instagram.com/gusrobatto/
                    www.facebook.com/gusrobatto
                    • Gus RG Offline
                      Gus R
                      After getting stuck in a rabbit hole using Sketchucation Tools it does load and work but then as I started I can't get it to validate the license that I purchased as SCF_Purchased_License_RoundCorner_NORMAL_20220401.scflicense.
                      It's looking for FredoCorner.scflicense
                      The rbz is FredoCorner_v2.5a.rbz which is the latest and the library is also the latest.
                      • chonC Offline
                        chon
                        Hello,
                        RoundCorner and FredoConer are two different plugins.
                        The licence of the first one can't be used for the second one. πŸ˜‰
                        • chonC Offline
                          chon
                          Hello,
                          Is your LibFredo6 up to date ?
                            Mariotalluto
                            Thanks Fredo,
                            Where can we get the bill after buying ? I baught the bundle
                            • Gus RG Offline
                              Gus R
                              Everything is up to date.
                              After fumbling around I'm all set now and everything is licensed. 😲
                              @chon said:
                              Hello,
                              • pep75P Offline
                                pep75
                                Suddenly I get an error message about licensing...Everything seems to be fine but everytime I want to use the plugin I got the license message. After updating I get the same error message again. Please help! I updated all plugins and I'm running SU as an administrator.
                                  See this thread for the update details...
                                  https://sketchucation.com/forums/viewtopic.php?f=323&t=73325
                                    @higherwire said:
                                    I may have missed it...
                                    See the link in the post prior to yours.
                                    • H Offline
                                      higherwire
                                      I may have missed it, but where can we find a link to the licenses? I see the instruction to "Purchase the license on Sketucation," but there's nothing I can find on the website.
                                      EDIT: It wasn't popping up in Sketchup. I uninstalled and reinstalled from the SketchUcation store within Sketchup, closed and reopened Sketchup, and was able to get to the license link by clicking the extension icons.
                                      • N Offline
                                        nirmwood
                                        Hi Fredo,
                                        I just bought your Fredobundle pack. Been an ardent user for years and well worth the money.
                                        Unfortunately I realized that I had bought Fredopushpull independently of the pack before this, and now I'm stuck with 2 licenses with one unused that came with the pack. Could it be possible to swap out one with that of FredoCorner?, thats the only one I'm missing a license for atm.
                                        Would be much obliged if this were possible!
                                        • N Offline
                                          nirmwood
                                          @nirmwood said:
                                          Hi Fredo,
                                          [attachment=0:2vaggisi]<!-- ia0 -->fredotools.png<!-- ia0 -->[/attachment:2vaggisi]
                                          Couldn't reply to you via inbox due to site restrictions so replying here!
                                          Thank you so much Fredo6!, you made my day and I'm even more glad I made the purchase πŸ˜„
                                          • N Offline
                                            necoopanik
                                            I cannot buy because Paypal is closed in our country (Turkey). Can you help me how else can I get it?
                                            • 8
                                            • 9
                                            • 3 / 9
