    [Plugin] MoveAlignMe (MAM) - v1.4a - 02 Apr 24
    19 Posts 9 Posters 17.2k Views 9 Watching
    • fredo6F Offline
      fredo6
      The information on MoveAlignMe is maintained on the Plugin Home Page of MoveAlignMe. This is also where you can download the RBZ file.
      • LibFredo6: v14.3b or above
      • Usage: Free for the time being
      If you land on this page and are unfamiliar with how to install Sketchup Extensions such as LibFredo6 or how to register on Sketchucation, please watch this video or refer to the Plugin page of LibFredo6.
      MoveAlignMe (MAM) performs the move and alignment objects interactively. Objects can be Components, Groups, Faces (and surfaces), Edges (and curves) and Images.
      It includes the two tools :
      1. Move-Pivot-Straighten, which performs a translation, folllowed by a free pivoting followed by a planar rotation
      2. Move and Glue, which automatically rotates object(s) when moved over a target face or edge, aligning their blue axis with the face normal or edge direction. It also perform gluing and cut-opening for components, and since SU2021.1, for groups and images.
      The user manual of is available interactively in the Instructor window of each tool. This help can also be displayed and printed in a dedicated help panel, which can be called from the contextual menu.
      Here are the 2 documentations in PDF.
      MAM - Move-Glue - User Manual English - v1.1c.pdf
      MAM - Move-Pivot-Straighten - User Manual English - v1.1c.pdf
      1) Move-Pivot-Straighten - overview
      2) Move & Glue - Overview
      3) Move & Glue - Deep Gluing
      There is also a good overview by TutorialsUp:
      And one by TheSketchupEssentials:
      • Rich O BrienR Online
        That looks very impressive Fredo. Can't wait to try it out.
          RLGL
          Oct 24, 2021 1_45_35 PM.pdfOct 24, 2021 12_58_35 PM.pdfThe plug in ghosted me. I have tried multiple times to install, it shows in the Extension Manager but it is not listed in the Fredo6 Collection. The Ruby console is blank. I did get the message that is with this post. There have been multiple trys to get it to show, restarting Sketchup and the computer. The files that are in the AppData folder are also attached.
          • fredo6F Offline
            fredo6
            @rlgl said:
            [attachment=0:1k9wtyle]<!-- ia0 -->Oct 24, 2021 1_45_35 PM.pdf<!-- ia0 -->[/attachment:1k9wtyle][attachment=1:1k9wtyle]<!-- ia1 -->Oct 24, 2021 12_58_35 PM.pdf<!-- ia1 -->[/attachment:1k9wtyle]The plug in ghosted me. I have tried multiple times to install, it shows in the Extension Manager but it is not listed in the Fredo6 Collection. The Ruby console is blank. I did get the message that is with this post. There have been multiple trys to get it to show, restarting Sketchup and the computer. The files that are in the AppData folder are also attached.
            As indicated in the message, you need to install the latest version of LibFredo6, v12.1.
              RLGL
              My bad, the update checker did not indicate there was an update to Libfredo 6.
              • boofredlayB Offline
                boofredlay
                Bravo! Another tool I did not know I needed.
                Thank you.
                • fredo6F Offline
                  fredo6
                  NEW RELEASE: MoveAlignMe v1.1c - 31 Oct 21
                  Requirements
                  • LibFredo6: v12.1a
                  MoveAlignMe 1.1c includes Deep Gluing, which is the possibility to move a group or instance inside the group or component containing the target face, with gluing and cut-opening.
                  Home Page of MoveAlignMe for information and Download.
                  Main post of this MoveAlignMe thread.
                    rv1974
                    Fredo, thanks for the new tool! I really loved ability to put faces perpendicularly to the edges. However the new 'move inside the group with gluing and cut-opening' doesn't work for me - the cutting component does indeed get glued but stays out of hosting group. no cutting happens.
                    • fredo6F Offline
                      fredo6
                      I forgot a few explanations:
                      Deep Gluing has to be explictely activated by Toogle SHIFT. When activated, the target faces embedded in groups or components will be highlighted in lightgreen, indicating that the object will be moved inside the target group or component and gluing / cut-opening will apply on the target face.
                      This is illustrated in the video below
                        rv1974
                        Oh now it makes sense, thank you.
                        Suggestion: Could you implement (via Control key) multiple copying (one click = one copy), similarly to TT's one?
                        https://sketchucation.com/pluginstore?pln=tt_place_component
                        • alvisA Offline
                          alvis
                          Thanks πŸ‘
                            attar82
                            I have tried it from a Window model from the 3D Warehouse but it is not working
                              @attar82 said:
                              I have tried it...
                              What window from the 3D Warehouse?
                              You're using SketchUp 8 as indicated in your profile?
                                attar82
                                @dave r said:
                                @attar82 said:
                                I have tried it...
                                Apologies, this is the first time i am using this platform for quiieres
                                I updated my profile, I am using Sketchup 2021, I've sent you an email a couple of days before using Extension Warehouse.com. May i contact you via email, it is much easier.
                                I ve attached a video for my Query did you see it?
                                • fredo6F Offline
                                  fredo6
                                  NEW RELEASE: MoveAlignMe v1.2a - 14 Nov 21
                                  Requirements
                                  • LibFredo6: v12.2a
                                  MoveAlignMe 1.2a fixes a major bug when processing multiple elements in copy mode. The result was not exploded.
                                    Bells88
                                    does not work on sketchup 2020! I have installed everything correctly but no icons are popping up anywhere. I have many other Fredo6 plugins but this is the only one that doesn't work. suggestions?
                                      Actually, it does work in SketchUp 2020.
                                      Click on the picture.
                                      Did you restart SketchUp as directed when the extension was installed? The current version of LibFredo6 installed?
                                      Please update your profile. It says you are using a pre-2013 version.
                                      • fredo6F Offline
                                        fredo6
                                        NEW RELEASE: MoveAlignMe v1.3a - 24 Feb 24
                                        Requirements
                                        • LibFredo6: v12.2a
                                        MoveAlignMe 1.3a is for bug fixing and future compatibility.
                                        • fredo6F Offline
                                          fredo6
                                          NEW RELEASE: MoveAlignMe v1.4a - 01 Apr 24
                                          Requirements:
                                          • LibFredo6: v14.3b
                                          MoveAlignMe 1.4a is a maintenance release for:
                                          • future compatibility.
