Are the plugins on sketchUcation compatible with 2021 pro?
Hello, new to sketchup. Just wondering if all the plugins are updated to be compatible with 2021 pro yet? I'm having trouble with plugins because they haven't been updated yet. I'd rather not pay for the upgraded service if I have to wait for the updates.
Thanks!
Most of the extensions available here are up to date. Which extension are you having difficulty with specifically?
What upgraded service are you talking about?
Hi Dave,
Thanks for replying. I haven't tried downloading any extensions from sketchUcation yet because I saw that it costs $75/year or so for access to them. (That's what I meant by upgraded service).
The PathCopy extension in the SU warehouse is not compatible with my 2021 version, but sketchUcation has a JHS Powerbar plugin called Copy Along Path that I'd like to get. Is the $75/year worth it? I do use SU for income.
There is no 'upgrade'.
You have misunderstood...
You also have full access to the SketchUcation PluginStore's RBZs' downloads as a 'free-account' member.
But a paid 'Premium' membership does give you extra benefits - discounts/freebies at the Shop etc...Most Plugins here will be compatible - if they are definitely not they will be flagged in their details.
Obviously a very old dated entry [e.g. that hasn't been updated for some time] might not work with newer versions - you can but try it anyway...On a separate note - if an Extension is not listed as compatible with a newer version it does not mean that it will not work... try it...
Perhaps the author hasn't updated its entry in the site's database... -
Thank you TIG! I appreciate it!
TIG gave you the right information about the membership.
It may not be listed as compatible but it works just fine in SketchUp 2021.
FWIW, Copy ALong Path is available separately, too.
Register LoginAdvertisement
