    Collada file import doesn't include textures
    5 Posts 4 Posters 8.4k Views 4 Watching
      j_jones
      Since they recently cut off access to 2017 files, I tried switching to collada files.
      Sometimes they work but about half the time they import as a wireframe only and textures aren't applied.
      E.g. this model:
      https://3dwarehouse.sketchup.com/model/608c126f0acb73dd7e338aebf530613c/Steam-Punk-Gun
      When imported into Sketchup turns out like this:
      I can see in the file system that the textures look ok
      Thanks for any advice
      -J Jones
        With this one, anyway, the materials will be present in the model if you extract the folder along with the .dae file from the .zip file and put them in the same location. The model is not coming as wireframe with no faces, the materials are all set to be fully transparent. Not sure why that would be but it's easily fixed.
        Edit the materials to remove the transparency.
          j_jones
          Thanks, that worked.
            cesom
            ► I found a trick to keep downloading 3D Warehouse models for 2017, for 2018 it doesn't work for everyone.
            ►►►►► TUTOS FREE GRATUITS SKETCHUP YOUTUBE ◄◄◄◄◄
            ►►►►► DISPLAY THE SUBTITLES
            • HornOxxH Offline
              HornOxx
              @dave r said:
              With this one, anyway, the materials will be present in the model if you extract the folder along with the .dae file from the .zip file and put them in the same location. The model is not coming as wireframe with no faces, the materials are all set to be fully transparent. Not sure why that would be but it's easily fixed...
              Thanks! This is a very helpful and valuable tip because I also failed at the "wireframe trap" like j_jones 👍 😄 and so I finally found out how to download the material package as well what I hadn´t done so far.
              never trust a skinny cook
