    Rendering 2d people w/toon material question
    renderpluginsextensions
    2 Posts 2 Posters 7.5k Views 2 Watching
    • o2bwlnO
      o2bwln
      Hello all,
      I'm trying to render 2d silhouette people w/the lines showing, I can only get the outline to show up, is there a way to have the inner-lines render that show the arms etc.; even with the toon material, the lines are not showing up.
      Would certainly appreciate any advice.
      Thank you.
      • sfto1S
        sfto1
        What rendering engine are you using?
        I use Thearender and it allows for the lines from Sketchup to merge with the rendering. There are times I only want the lines for certain elements, so I composite different renderings in a photo editor to get the results I'm looking for.
