    How to set dimensions via text
    11 Posts 4 Posters 5.4k Views 4 Watching
    • G Offline
      GilliganU
      I searched for how to set the dimensions of an object via text and there was no search results. Using push/pull is real cute and all, for rough ideas, but it is painfully annoying to set to an exact number.
      How do I do this?
      P.S. I'm using free web version
      • BoxB Offline
        Like all tools in sketchup you just start an action then let go of the mouse and type what you want and hit enter to finish.
        • G Offline
          GilliganU
          I use push/pull to start changing a length, then type the TOTAL length I would like. That is NOT what length ends up as!
          What EXACTLY does this do?
          How do I set the EXACT length I need?
            cesom
            You must display the subtitles to watch the tutorial in English or Spanish.
            This tutorial, a little old but still valid, explains how to give dimensions with the push pull tool and also how to resize lengths.
            ►►►►► TUTOS FREE GRATUITS SKETCHUP YOUTUBE ◄◄◄◄◄
            ►►►►► DISPLAY THE SUBTITLES
            • BoxB Offline
              Many people don't know that you can use the scale tool to set specific dimensions simply by adding the unit on the end. It works in 3 dimensions and in any, even mixed, units.
                cesom
                It only works if the starting value is 1, right?
                • BoxB Offline
                  No, it will adjust to whatever you tell it to be.
                    cesom
                    This is a great tip. Thank you. You have to type in the units and not just the length, I understand. It works perfectly.
                    • BoxB Offline
                      Yes, without the units it is read as a percentage.
                      • BoxB Offline
                        I wonder if it will be another 11 years before Gilligan asks another question. I'm guessing anything over 3 hours means a long wait.
                        • Rich O BrienR Online
                          PEBKAC?
