    How to set dimensions via text
    11 Posts 4 Posters 5.3k Views 4 Watching
    • BoxB Offline
      Like all tools in sketchup you just start an action then let go of the mouse and type what you want and hit enter to finish.
        GilliganU
        I use push/pull to start changing a length, then type the TOTAL length I would like. That is NOT what length ends up as!
        What EXACTLY does this do?
        How do I set the EXACT length I need?
          cesom
          You must display the subtitles to watch the tutorial in English or Spanish.
          This tutorial, a little old but still valid, explains how to give dimensions with the push pull tool and also how to resize lengths.
          ►►►►► TUTOS FREE GRATUITS SKETCHUP YOUTUBE ◄◄◄◄◄
          ►►►►► DISPLAY THE SUBTITLES
          • BoxB Offline
            Many people don't know that you can use the scale tool to set specific dimensions simply by adding the unit on the end. It works in 3 dimensions and in any, even mixed, units.
              cesom
              It only works if the starting value is 1, right?
              • BoxB Offline
                No, it will adjust to whatever you tell it to be.
                  cesom
                  This is a great tip. Thank you. You have to type in the units and not just the length, I understand. It works perfectly.
                  • BoxB Offline
                    Yes, without the units it is read as a percentage.
                    • BoxB Offline
                      I wonder if it will be another 11 years before Gilligan asks another question. I'm guessing anything over 3 hours means a long wait.
                        PEBKAC?
