    [Plugin] LordOfTheToolbars - v4.1a - 20 Oct 26
    532 Posts 101 Posters 591.6k Views 99 Watching
    • M
      Mike Backman
      @fredo6
      I'm have a tough time getting answerer regarding you products. Forgive me I'm new to using a public forum for customer service . I don't know how to message fredo directly please help.
      I have tried several times to figure out why I cannot get LOTT to vignette to show up on my external monitor. (using SU 24 on windows laptop. and LG second monitor. ) In order to use LOTT on my big external monitor I need to make the 2nd screen my "main screen" with in the display settings. This allows the LOTt vignettes to travel off the laptops screen and into my work space of SU. this makes a ton of problems with other programs and my desktop is a mess when I'm working only on my laptop.
      fredo6F F 2 Replies Last reply
      • fredo6F
        fredo6 @Mike Backman
        @Mike-Backman
        There is no control of the API over monitors, not even an access to information.
        So, it might not work with LOTT, but I can't do anything about it.
        • F
          FlorinAp @Mike Backman
          @Mike-Backman This happens with other few programs (but mostly with Sketchup and Sketchup extensions) when you have set different DPi (other than the native one for each monitor) for one or more monitors.
          Sometimes, windows by default sets arbitrary DPi different than the native one of your monitor.
          You just have to check and manually choose the default DPi.
          M 1 Reply Last reply
          • M
            Mike Backman @FlorinAp
            @FlorinAp I currently use and have tried tons of SU plug ins I have never seen this..
            Where would I find The "DPI " settings on my windows machine are you talking about Resolution?
            F 1 Reply Last reply
            • M
              Mike Backman
              And As of just recently I cannot add new tools to existing pallets. If i drag a tool from 1 pallet or even from the master palette it'll erase the nearest tool. So I cannot add new tools or adjust how my tools are set up anymore.
              R 1 Reply Last reply
              • M
                Mike Backman
                LOTT Not moving tools .mp4
                • R
                  rv1974 @Mike Backman
                  @Mike-Backman yep I see constantly it never got fixed for years. hopeless
                  • fredo6F
                    fredo6
                    Which versions of LibFredo6 and LOTT do you have?
                    • M
                      Mike Backman @fredo6
                      • F
                        @Mike-Backman Resolution is resolution, and DPi is DPi.!
                        fredo6F M 2 Replies Last reply
                        • fredo6F
                          fredo6 @FlorinAp
                          @FlorinAp
                          Can you leave the Ruby console open, while dragging icons in LOTT.
                          Just check the possible errors.
                          • M
                            Mike Backman
                            Nothing pops on the Ruby Console
                            • M
                              @FlorinAp I still don't see DPI settings for my windows machine
                              • M
                                @fredo6 Nothing happens with the Ruby console for moving icons .
                                also the bigger problem is needing to make my external monitor the "main" monitor. This really screws up my laptop for when I'm not in my office
                                • F
                                  @Mike-Backman Sorry to say it (this being also a reply for many of your posts), but you don't know how to use your OS, and as such you shouldn't be allowed to use any other app.!
                                  Reply Quote -1
                                  • M
                                    @FlorinAp DUDE BE HELPFULL!!OR DONT SAY ANYTHING!
                                    Reply Quote -1
                                    • fredo6F
                                      fredo6
                                      For the monitors, do you have the stickiness option activated in the Default Parameters. This forces the vignette stripe to follow the main Sketchup window.
                                      For the issue when moving icons between palettes, I cannot reproduce it on SU2024, and latest versions of LibFredo6 and LOTT.
                                      Are you sure you do not get errors in the Ruby console?
                                      What happens if you move an icon to an empty palette?
                                      • M
                                        @fredo6 I do have the stickiness tab checked
                                        And When I create a new palette No matter what I do I am limited by the amount of plugins I can put into that new palette LOTT Prob.mp4
                                        fredo6F 1 Reply Last reply
                                        • M
                                          @fredo6
                                          I just saw that I had the default for new pallets set to 10 and not higher b5b204cd-1950-406c-9a9e-2810b0c578ed-image.png
                                          Still fighting with the "make this my main window" in display setting. Still don't know how to adjust the "dots per inch setting" or DPI as referred by the girl in the previous reply.
                                          • fredo6F
                                            @Mike-Backman
                                            Can you try with a NEW palette.
                                            In the video, you already have icons in the palette. How did you insert them ?
                                            M fredo6F 2 Replies Last reply
                                            • 20
                                            • 21
                                            • 22
                                            • 23
                                            • 24
                                            • 25
                                            • 26
                                            • 27
                                            • 22 / 27
