    [Plugin] LordOfTheToolbars - v4.0a - 22 Sep 26
    529 Posts 101 Posters 588.5k Views 99 Watching
    • H
      haymaker @fredo6
      @fredo6
      I just upgraded to SU2024
      My personal icons I made in 2022 are greyed out. when i try to make a new one there is no list available in the command menu, same as larent002.
      Is this going to be fixed?
      Do you have a work around?
      I am missing 6 buttons that I need all the time.
      • O
        olopolo
        Hello,
        I can't enlarge the “Master toolbar manager” window to reach the “custom toolbars” line.
        The window remains at this size and the scroll bar doesn't just go to the end.
        By however, you can see this line in the “print toolbars” window.
        Thank you in advance for your help and with apologies for this message translated from French
        • H
          haymaker
          Hi Fedo.
          I have created some keyboard shortcuts to open custom made LOTT pallets. The problem is when I create a new tag or tag folder and one of the shortcut keys is pressed it activates the shortcut and the pallet opens making it impossible to create the tag. It doesn't happen if the shortcut letter is assigned to a native SU command only if it is controlling a LOTT pallet. After trying various things like adding an Alt before the letter now none of the LOTT shortcut keys are working, shortcuts created using SU native UI still work fine. My problems started a few weeks back when I updated to 2024 from 2022. Running Fredo 15.0 and LOTT 2.9c. Please could you offer some assistance as I cant find a work around. Thank you.
          • fredo6F
            Shortcuts for LOTT commands should have a modifier.
            Because there have been changes in the UI framework of Sketchup in SU2023 and SU2024 (versus SU2022), many things are done differently now.
            • H
              haymaker
              This post is deleted!
              • H
                haymaker
                OK. I was using shift as a modifier key in the past but if you want to add a capital letter when creating a tag title it would activate the palette.
                I can use Ctrl instead, but the problem is compounded by the fact that I use a space mouse key with macro to open LOTT pallets and LOTT no longer seems to recognise the output (it used to) from the space mouse. The problem would appear to be at your end. Example - if I map ctrl A to a native SU shortcut the space mouse executes the command fine but if I map ctrl A to a LOTT pallet when I press the space mouse key I just get a red + flash up momentarily. Thanks
                  Ramzix
                  Hi there, humble question, is there a way to possibly get an older version of LOTT? Like 2.7c
                    Mike Backman
                    @fredo6
                    I'm have a tough time getting answerer regarding you products. Forgive me I'm new to using a public forum for customer service . I don't know how to message fredo directly please help.
                    I have tried several times to figure out why I cannot get LOTT to vignette to show up on my external monitor. (using SU 24 on windows laptop. and LG second monitor. ) In order to use LOTT on my big external monitor I need to make the 2nd screen my "main screen" with in the display settings. This allows the LOTt vignettes to travel off the laptops screen and into my work space of SU. this makes a ton of problems with other programs and my desktop is a mess when I'm working only on my laptop.
                    fredo6F F 2 Replies Last reply
                    • fredo6F
                      fredo6 @Mike Backman
                      @Mike-Backman
                      There is no control of the API over monitors, not even an access to information.
                      So, it might not work with LOTT, but I can't do anything about it.
                      • F
                        FlorinAp @Mike Backman
                        @Mike-Backman This happens with other few programs (but mostly with Sketchup and Sketchup extensions) when you have set different DPi (other than the native one for each monitor) for one or more monitors.
                        Sometimes, windows by default sets arbitrary DPi different than the native one of your monitor.
                        You just have to check and manually choose the default DPi.
                        M 1 Reply Last reply
                          Mike Backman @FlorinAp
                          @FlorinAp I currently use and have tried tons of SU plug ins I have never seen this..
                          Where would I find The "DPI " settings on my windows machine are you talking about Resolution?
                          F 1 Reply Last reply
                            Mike Backman
                            And As of just recently I cannot add new tools to existing pallets. If i drag a tool from 1 pallet or even from the master palette it'll erase the nearest tool. So I cannot add new tools or adjust how my tools are set up anymore.
                            R 1 Reply Last reply
                              Mike Backman
                              LOTT Not moving tools .mp4
                                rv1974 @Mike Backman
                                @Mike-Backman yep I see constantly it never got fixed for years. hopeless
                                • fredo6F
                                  Which versions of LibFredo6 and LOTT do you have?
                                    Mike Backman @fredo6
                                    • F
                                      @Mike-Backman Resolution is resolution, and DPi is DPi.!
                                      fredo6F M 2 Replies Last reply
                                      • fredo6F
                                        fredo6 @FlorinAp
                                        @FlorinAp
                                        Can you leave the Ruby console open, while dragging icons in LOTT.
                                        Just check the possible errors.
                                          Mike Backman
                                          Nothing pops on the Ruby Console
                                            @FlorinAp I still don't see DPI settings for my windows machine
                                            • 20
                                            • 21
                                            • 22
                                            • 23
                                            • 24
                                            • 25
                                            • 26
                                            • 27
                                            • 22 / 27
