    [Plugin] LordOfTheToolbars - v4.0a - 22 Sep 26
    529 Posts 101 Posters 588.5k Views 99 Watching
    • F
      FlorinAp @Mike Backman
      @Mike-Backman This happens with other few programs (but mostly with Sketchup and Sketchup extensions) when you have set different DPi (other than the native one for each monitor) for one or more monitors.
      Sometimes, windows by default sets arbitrary DPi different than the native one of your monitor.
      You just have to check and manually choose the default DPi.
      M 1 Reply Last reply
        Mike Backman @FlorinAp
        @FlorinAp I currently use and have tried tons of SU plug ins I have never seen this..
        Where would I find The "DPI " settings on my windows machine are you talking about Resolution?
        F 1 Reply Last reply
          Mike Backman
          And As of just recently I cannot add new tools to existing pallets. If i drag a tool from 1 pallet or even from the master palette it'll erase the nearest tool. So I cannot add new tools or adjust how my tools are set up anymore.
          R 1 Reply Last reply
            Mike Backman
            LOTT Not moving tools .mp4
              rv1974 @Mike Backman
              @Mike-Backman yep I see constantly it never got fixed for years. hopeless
              • fredo6F
                Which versions of LibFredo6 and LOTT do you have?
                  Mike Backman @fredo6
                  • F
                    @Mike-Backman Resolution is resolution, and DPi is DPi.!
                    fredo6F M 2 Replies Last reply
                    • fredo6F
                      fredo6 @FlorinAp
                      @FlorinAp
                      Can you leave the Ruby console open, while dragging icons in LOTT.
                      Just check the possible errors.
                        Mike Backman
                        Nothing pops on the Ruby Console
                          @FlorinAp I still don't see DPI settings for my windows machine
                            @fredo6 Nothing happens with the Ruby console for moving icons .
                            also the bigger problem is needing to make my external monitor the "main" monitor. This really screws up my laptop for when I'm not in my office
                            • F
                              @Mike-Backman Sorry to say it (this being also a reply for many of your posts), but you don't know how to use your OS, and as such you shouldn't be allowed to use any other app.!
                              Reply Quote -1
                                @FlorinAp DUDE BE HELPFULL!!OR DONT SAY ANYTHING!
                                Reply Quote -1
                                • fredo6F
                                  For the monitors, do you have the stickiness option activated in the Default Parameters. This forces the vignette stripe to follow the main Sketchup window.
                                  For the issue when moving icons between palettes, I cannot reproduce it on SU2024, and latest versions of LibFredo6 and LOTT.
                                  Are you sure you do not get errors in the Ruby console?
                                  What happens if you move an icon to an empty palette?
                                    @fredo6 I do have the stickiness tab checked
                                    And When I create a new palette No matter what I do I am limited by the amount of plugins I can put into that new palette LOTT Prob.mp4
                                    fredo6F 1 Reply Last reply
                                      @fredo6
                                      I just saw that I had the default for new pallets set to 10 and not higher b5b204cd-1950-406c-9a9e-2810b0c578ed-image.png
                                      Still fighting with the "make this my main window" in display setting. Still don't know how to adjust the "dots per inch setting" or DPI as referred by the girl in the previous reply.
                                      • fredo6F
                                        fredo6 @Mike Backman
                                        @Mike-Backman
                                        Can you try with a NEW palette.
                                        In the video, you already have icons in the palette. How did you insert them ?
                                        M fredo6F 2 Replies Last reply
                                          @fredo6 I told you in the previous reply I figures out the Limited Pallet size was because I had the Maximum number of icons for favorites set to 10 for some reason.
                                          I'm still struggling with the Monitor connection. I cannot get the vignette strip to jump on my secondary monitor. un less it is made the "main display
                                          . Untitled video (2).mp4
                                          • fredo6F
                                            fredo6 @fredo6
                                            @fredo6
                                            Go to the menu Tools > Fredo6 Collection > LordOfTheToolbars.
                                            Can you try Reset the Vignette Stripe Position, after you moved Sketchup to the other monitor.
                                            Note that there is no event received by the API when you move Sketchup between monitors. So, you cannot expect that the dialogs would follow.
                                            • 20
                                            • 21
                                            • 22
                                            • 23
                                            • 24
                                            • 25
                                            • 26
                                            • 27
                                            • 22 / 27
