    Issue with install
    Scheduled Pinned Locked Moved FlexTools
    renderpluginsextensions
    3 Posts 2 Posters 5.7k Views 2 Watching
    • P
      pibuz
      Hi Hal and FlexTools developer, here to report a strange issue.
      One of my students had flextools installed without any problems. Then she happened to leave her noteebook disconnected from power so the pc auto-shut down. From the following power-on, she gets this message when starting SKP 2020:
      Error: #<JSON::ParserError: 765: unexpected token at ''>
      C:/Program Files/SketchUp/SketchUp 2020/Tools/RubyStdLib/json/common.rb:156:in parse' C:/Program Files/SketchUp/SketchUp 2020/Tools/RubyStdLib/json/common.rb:156:in parse'
      C:/Program Files/SketchUp/SketchUp 2020/Tools/RubyStdLib/json/common.rb:335:in load' c:/users/lambertini-m/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/f3d_flextools/main.rbe:6301:in block in filedata'
      c:/users/lambertini-m/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/f3d_flextools/main.rbe:6300:in open' c:/users/lambertini-m/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/f3d_flextools/main.rbe:6300:in filedata'
      c:/users/lambertini-m/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/f3d_flextools/main.rbe:6291:in load' c:/users/lambertini-m/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/f3d_flextools/main.rbe:6414:in filedata'
      c:/users/lambertini-m/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/f3d_flextools/main.rbe:6393:in load' c:/users/lambertini-m/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/f3d_flextools/main.rbe:6810:in fetch_serial'
      c:/users/lambertini-m/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/f3d_flextools/main.rbe:6774:in init' c:/users/lambertini-m/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/f3d_flextools/main.rbe:6731:in method_missing'
      c:/users/lambertini-m/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/f3d_flextools/main.rbe:9763:in setup' c:/users/lambertini-m/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/f3d_flextools/main.rbe:9825:in module:FlexTools'
      c:/users/lambertini-m/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/f3d_flextools/main.rbe:19:in <module:F3d>' c:/users/lambertini-m/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/f3d_flextools/main.rbe:18:in <main>'
      C:/Program Files/SketchUp/SketchUp 2020/Tools/extensions.rb:197:in eval' C:/Program Files/SketchUp/SketchUp 2020/Tools/extensions.rb:197:in require'
      C:/Program Files/SketchUp/SketchUp 2020/Tools/extensions.rb:197:in load' C:/Users/lambertini-m/AppData/Roaming/SketchUp/SketchUp 2020/SketchUp/Plugins/f3d_flextools.rb:17:in register_extension'
      Basically, the rbz installs without errors BUT I get no toolbars, although FlexTools is present in the list of the installed extensions.
      I tried uninstalling the plugin, uninstalling SKP, repairing SKP, running CCleaner after uninstall, installing SU2021, but the issue still remains, so I believe it's not related to SKP but maybe to some registry key I suppose has been corrupted during the auto-shut down.... But I'm no expert, that's only an hypothesis....
      Could you help me out solving this problem? Thanks in advance!
      WEB (ita) - https://filipposcarso.wixsite.com/ordinentropico
      • halroachH
        halroach
        Hi Filippo,
        Very sorry about this. Please try the following:
        1. Close Sketchup.
        2. Go to: C:\Users[YOUR USER NAME]\AppData\Local\F3d_FlexTools and delete 3 files:
          pkg_serial
          pkg_serial.json
          serial.json
        (If you can't see the AppData folder it's probably hidden. Instead, open a Windows Folder (any folder) and Paste C:\Users%USERNAME%\AppData\Local\F3d_FlexTools\ into the address bar. Then delete the 3 files above).
        1. Open Sketchup. You may need to reactivate FlexTools by going into the FlexTools Manager (gear icon) and entering your license key.
        If there are any issues activating, have your Student send us an email - https://flextools.cc/contact/
        FlexTools - Super Quick Windows, Doors, Slats...
        • P
          pibuz
          Thanks a lot for you quick answer!
          I'll try and let you guys know! Thanks!
          *** EDIT ***
          That fixed the issue! Thanks again!
