    How do I extrude a 2D profile along multiple lines at once?
    4 Posts 4 Posters 2.2k Views 4 Watching
      silbedia
      I'm in the process of turning a 2D design pattern into 3D openwork tracery. What I've been doing is using the Follow Me tool for each individual curve. I've been trying to find a different method that would save time by allowing me to take a 2D profile and extrude it on all of the selected curves instead of doing each one at a time. Attached picture is results after 30-40 minutes of work using follow me.
      The closest thing I've found is the lines to tubes plugin, but that obviously only creates cylinders. I've used Extrude Tools a lot for my work; extrude edges by faces sounds like what I need but that specific tool doesn't seem to work at all.
      If anyone has a solution please let me know.
        You can't do multiple extrusions at the same time. It looks to me as if there are a number of repeated shapes, though. You could be making good use of components and use the same extrusions more than once which would save you a lot of time. I would be making solid components so I could trim them with Eneroth Solid Tools at the ends to get the correct shapes.
          Another way MIGHT be to use 'line to tube" plugin. Perhaps you could turn the lines into tubes and squash the result to make them ovaloid. Just a thought
            TBoy
            '1001 bits Pro' has some extrusion tools to test.
