    Face fragments
    8 Posts 3 Posters 2.7k Views 3 Watching
      Leggie
      Ive been noticing this lately
      For example, I draw a circle with a smaller circle in side to make a ring, I pull the ring100mm , I get lines down the tube and the face of the pulled ring is fragmented into a mass of sections viewed in hidden construction
      What’s happening?
        Leggie
        Also if I pull one shape through another and intersect them , part of a face disappears
          Leggy
          I hope this shows what I mean
          SC1408 1.25%224.dwg
          • HornOxxH Offline
            HornOxx
            Hi - hmmm, no idea what you are describing above - could you add any screenshots and the SKP file (saved down in any much older skp file version) instead of DWG?
            never trust a skinny cook
              Leggy
              this is before intersecting
              SU pic1.pdf
                Leggy
                this is after, notice the hidden geometry
                SU pic2.pdf
                  Leggy
                  and the skp
                  SC1408 1.25%224 copy.skp
                  • HornOxxH Offline
                    HornOxx
                    ... as asked above, could you please save down your SKP-file? This also enables users of older versions (like me) to help because not everyone has the current version. Sreenshots you can post as jpg directly visible here instead of making pdf files which have to be downloaded first which makes looking so cumbersome.
                    And if you take a new screenshot, it doesn't hurt to highlight the places that bother you (the example-jpg below is screenshoted with the free Greenshot tool).
                    I still don't see where the problem is. The pure presence of hidden geometry in itself is nothing unusual but normal. I can't be more specific without having a skp.
                    [the only indication that immediately strikes me is the tube shape, which appears to be segmented into an absurdly high number of circular segments]
