    πŸ”Œ Easy Offset | Offset selected faces in SketchUp in positive and negative offsets. Download
    Beach Sunset
    16 Posts 8 Posters 2.8k Views 8 Watching
    • tuna1957T Offline
      tuna1957
      Time for a tasty adult beverage ? Been going back into old practice models and messing about for fun. Seeing if I can get a better result the second time around. Rendered in Twilight , post pro in Gimp. Shout out to Pixero for his nice palm trees available in the sketchUcation store.
      • ntxdaveN Offline
        ntxdave
        Looks good! πŸ‘
        I would like for the sun to be a little higher so that we could see the furniture just a little better (at least on my iPad). πŸ˜„
        BTW: I think the shadows look very good! πŸ‘ πŸ‘
        Press F1...thank me later
        • pbacotP Offline
          Let's go! Nice image!
            Hi Tuna........nice work! I would suggest that you alter the sun colour in the renderer to a more yellow orange of the sunset, the sun position is perfect direction wise, but I think the colour temperature change would really make the image more cohesive.
            Cheers
            • jenujacobJ Offline
              jenujacob
              Cheers
              i wanted to say the same...
                @ntxdave said:
                Looks good! πŸ‘
                Agreed, but I think that could be done by assuming there is a lit venue behind the camera, say a resteraunt with lighting that would acheive the effect. So a number of light sources behind the camera, perhaps?
                • HornOxxH Offline
                  HornOxx
                  @ntxdave said:
                  Looks good! πŸ‘
                  πŸ˜„ πŸ˜‰ πŸ˜„ and I I would like to sit there tasting the drink ("adult beverage" - this is a strange naming - is this a used naming?)
                  never trust a skinny cook
                  • pbacotP Offline
                    It's a euphemism, probably originally used in polite references such as public announcements or advertising, now used in fun. Like "adult bookstore".
                    • pbacotP Offline
                      I have to comment on the picture though. Where's the light (shadows) coming from? Is it lit by the HDRI? Shadows look a little high. I would expect the vanishing point of the railing lines to go to the horizon. It seems to be above the horizon. I still like it though.
                      • tuna1957T Offline
                        tuna1957
                        Thanks everyone for your comments and input. Guess I should have put this in "work in progress" as I'm sure I'll fool with it some more. Was curious about a few of the comments about how dark the image is viewed on some iPads'. Checked the post on an iPad and it is way darker than on my iMac that I used to do the work... go figure. pbacot I found your comments on the horizon interesting. The deck sits several feet above the origin , the "beach" plane is on the origin. Did some experimenting with the background image to get it lined up with the "beach". The edge of the water and land in the background image ended up a little lower than the railing. If this wasn't the right approach for figuring it out anyone is welcome to chime in with advice. This was defiantly more of a rendering and post pro exercise for me so all comments and advice is much appreciated. Just trying to get better I hope. 😎
                        • tuna1957T Offline
                          tuna1957
                          Made some minor changes to model and ran a new render. New render was with depth of field enabled . Better or worse you be the judge... πŸ˜•
                          • Bryan KB Offline
                            Yes! That's it! πŸ‘
                            Well done!
                            • tuna1957T Offline
                              tuna1957
                              Thanks Bryan πŸ‘
                              • pbacotP Offline
                                I like the second one more.Nice work!
                                • tuna1957T Offline
                                  tuna1957
                                  Thanks pbacot .
                                    I do prefer the second but that's for accuracy sake, mood wise they both rock the clock. Very nice. πŸ‘Š
