    Small cutting problem with VisuHole?
    19 Posts 6 Posters 4.7k Views 6 Watching
    • E
      ericbruggema
      I've got a small problem with visuhole, i can't cut thru walls...
      https://www.dropbox.com/s/i46v3pobdw6kee2/visuhole%20-%20no%20holes.skp?dl=0
      In the example you'll see the outer osb and rabat wood, i want to cut the roof but i can't..
      What am i doing wrong?
      https://s2.gifyu.com/images/visuholeerror.gif
      Is it because i use components? osb plate 1220x2440?
      • fredo6F
        fredo6
        Can you check the options for component selection.
        • E
          ericbruggema
          [attachment=0:wk2cmptf]<!-- ia0 -->VisuHole options Components.png<!-- ia0 -->[/attachment:wk2cmptf]
          I've tried them all, with no luck....
          • E
            ericbruggema
            I've tried many things..
            see gif
            https://i.imgur.com/nuNItvn.gif
              Can't load your file!
              In your profil it's writed 2014 but seems your file posted is not that!
              If you can send a skp V6 to V 2017 format that will be fine!
              • E
                ericbruggema
                Sorry didn't change that, its in 2018 format.
                • BoxB
                  Fredo there is some odd behavior that may be related to this.
                  If you have a Component made of components Visuhole will cut through it, but if you have more than one it will make the one you use, unique, and cut the holes in the other.
                  This doesn't happen with a simple component, it becomes unique and gets the hole while the others remain untouched.
                  Here is an example of what I mean with the complex component of components.
                  I've added the file from the gif
                  • E
                    ericbruggema
                    Still getting problems, i've tried to remove the groups, make all items unique, but even then it didn't work...
                    Fredo... any idea's what to try next?
                    • fredo6F
                      fredo6
                      I am looking at it. Very strange, but definitely a problem....
                      • E
                        ericbruggema
                        Thanks for your response...
                        I've already done 90% of my work and with your plugin it saved me many hours of cutting things... but now the last part (the rabat wood) is still a big thing! πŸ˜‰
                        To test alot of things, i've ungrouped groups, made all components unique but it all made no difference... to bad... realy hope you find what's wrong! πŸ˜„
                        • E
                          ericbruggema
                          The problem still is there? how do i solve this?
                          Even purchased visuhole so i got the latest version... but that didn't work also.
                          Please give me tips, i've tried all options...
                            The video doesn't seem to be available at the link you provided. Share the .skp file with us so we can see your set up.
                            What version of SketchUp are you really using? Your profile says 2018 Free/Make but there is no such version.
                            • E
                              ericbruggema
                              Thanks for your reply, i've changed the status of the video so it should be available now. Can't share the skp file now coz i'm not home right now.
                              If needed after seeing the video, let me know and i'll get it to you.
                              • E
                                ericbruggema
                                I've added an example. Holes in the 'OSB' are already cutted with visuhole a couple of years ago.
                                The new Rabat wood doesn't want to be 'holed' using visuhole.
                                Tried many things, one thing works without visuhole and that's exploding all rabat groups and combining them together... then i can use the solidtools to make holes... but that's not what i want.. i want to keep the groups....
                                tuinhuis-muren-example.skp
                                • E
                                  ericbruggema
                                  Can someone tell me what im doing wrong?
                                  E 1 Reply Last reply
                                    If you enter the Muren Group and punch the Group with a Stencil then it will target what you need.
                                    https://i.imgur.com/4b0C33k.png
                                    You can see my settings above that I used.
                                    https://i.imgur.com/zY3ORxN.png
                                    • E
                                      ericbruggema
                                      Thanks for your response, i've tried it but doesn't seem to work.. i think i am doing something wrong??
                                      Is it possible that you make a small gif/video clip of how you did this?
                                      Again, thanks for your effort!!!
                                      • E
                                        ericbruggema @ericbruggema
                                        @ericbruggema said in Small cutting problem with VisuHole?:
                                        Still stuck on this one... can't figure out how you did this...
                                          Rich O Brien Moderator @ericbruggema
                                          @ericbruggema Does my picture not show the settings I had? I was inside the context of the group so I was targeting the item that needed punching. But also review the settings I had picked on the UI
