    V-Ray 3.4 non-tiled textures not showing up?
    renderpluginsextensions
    1 Posts 1 Posters 4.7k Views 1 Watching
    • eidam655E
      eidam655
      So I've recently circled back to using SU and V-Ray for a sideproject of mine. It is an interior refurbishment project and I wanted to explore the material options of a wardrobe assembly.
      What I wanted to do in V-Ray is apply a texture to the assembly. I largely succeeded, by using the Texture Blend material, with Texture A having the original color and Texture B the bitmap with alpha channel, setting Blend Amount to 1 and ticking the Composite box.
      leafy texture on a white surface
      However, if I wanted to see what it looks like at half the size (keeping the aspect ratio of the texture), I would get the image twice (four times in fact) on the whole doors. That's when I tried to untick the option "Tile" in the bitmap settings under the Placement tab.
      Tile option
      This however makes the texture completely disappear from the whole stack. I tried modifying the texture position in SU, in hopes of "finding" the decal, to no avail. Resizing the texture in SU also didn't bring any results.
      Is this a bug, or am I doing something wrong?
      Thanks for any ideas.
      I'm using SketchUp 2017, V-Ray 3.4
