    Bug Splat on Editing Comps or Groups
    4 Posts 2 Posters 6.7k Views 2 Watching
    • david_hD
      david_h
      Dear Wizards of Smart: I am having a 2020 problem. I just installed 20 for the first time this week and on using it on of my models, it seems that everytime I edit a component or group it splate on closing that C or G. is it a path problem? or a problem with the model itself? (updated from 19)
      any thoughts on this?
      Thx,
      D
      • TIGT
        Did you install SketchUp in the proper way ?
        I'm assuming you're on a PC ?
        Then you can try a 'Repair'...
        While logged into your normal Windows user-account, ensure that SketchUp is closed.
        Find its installer's exe file - usually in your Downloads folder ?
        Select the installer's exe file icon and right-click > context-menu > "Run as administrator"
        When prompted choose "Repair".
        This will reset file and folder permissions properly.
        Any complex app's installer should run that way, double-clicking its icon to 'Run' it is not the same, even if your user-account has admin-powers...
        If the problem continues then we need to consider some other possibilities...
        Are you working on a 'local' model or a network/cloud saved version ?
        Have you tried disabling Preferences > AutoSave ?
        Have you looked at your Preferences > OpenGL settings ?
        • david_hD
          david_h
          Thanks TIG.
          I think i installed correctly, but you never can tell with me. . . πŸ’š
          I will walk thru the "Administrator" stuff as per your suggestion.
          D
          **EDIT:**This just in. . .
          None of those suggestions solved the problem. So I will probably need to do a reinstall. Cr@p. 😞
          it seems to be something with the right-click context menu. I dunno.
          • david_hD
            david_h
            UPDATE this a chronic problem with the right mouse button click to save changes to componenent or group edit.I have done 2 installs, but when I uninstalled I guess it didnt do a complete uninstall because with the new install, the extensions prefernces and such that I had loaded came back rather than a fresh out of the box do-over. which if or the most part okay cuz I dont like re-loading all of that stuff. Funny. . .This was working fine yesterday, and I am not sure if I have a conflict with an extension. I hadn't loaded that many. Just enough to get me up and running in 2020.
            I unstialled most of them other than the "commercial" ones, etc.
            I dunno. If anybody out there has some ideas, I'd be grateful.
            D
