    Texture troubles
    7 Posts 5 Posters 3.2k Views 5 Watching
      critz1184
      I am trying to achieve a seamless backdrop using 2 planes @ 90 degrees and a radius joining them. My textures are not cooperating though. Any idea how to fix these alignment, scale issues ? Thanks in advance!
      https://i.imgur.com/ByBPLRg.png
        I can't see what you've got because it's so dark. I expect there's a solution for you but it would be helpful if you share the .skp file with us.
        What version of SketchUp are you using? Your profile indicates 2019 Free/Make which does not exist. Please correct your profile.
        • pbacotP Offline
          Try softening the edges separating the bend from the flat planes and reapply the texture.
            ThruPaint by Fredo
            and this
            click on the link for see the Youtube video!
            • HornOxxH Offline
              HornOxx
              ... as Pilou suggested above, Fredo6´s ThruPaint will do a fine job here. ThruPaint is one tool within Fredo6´s tool collection FredoTools.
              SketchUp Plugins | PluginStore | SketchUcation
              SketchUp Plugin and Extension Store by SketchUcation provides free downloads of hundreds of SketchUp extensions and plugins
              (sketchucation.com)
              never trust a skinny cook
                critz1184
                Thank you everyone, that totally fixed my issue. 😎
                • pbacotP Offline
                  You're right Thrupaint is the only way to do this nicely. I go to it automatically sometimes, and I forget.
