Texture troubles
I am trying to achieve a seamless backdrop using 2 planes @ 90 degrees and a radius joining them. My textures are not cooperating though. Any idea how to fix these alignment, scale issues ? Thanks in advance!
I can't see what you've got because it's so dark. I expect there's a solution for you but it would be helpful if you share the .skp file with us.
What version of SketchUp are you using? Your profile indicates 2019 Free/Make which does not exist. Please correct your profile.
Try softening the edges separating the bend from the flat planes and reapply the texture.
... as Pilou suggested above, Fredo6´s ThruPaint will do a fine job here. ThruPaint is one tool within Fredo6´s tool collection FredoTools.
https://sketchucation.com/pluginstore?pln=FredoTools
Thank you everyone, that totally fixed my issue.
You're right Thrupaint is the only way to do this nicely. I go to it automatically sometimes, and I forget.
