    How to move a shape along a path?
    15 Posts 5 Posters 2.6k Views 5 Watching
    • R
      RHA57
      Hi everyone,
      So i have created a particular path on a face of a circle. Now i want to move a circle along this path to dig it like "follow me" in 2D...It's like "thickening" the path.
      Can someone help me please?
      Thank you all
        Not enough information to help you without a lot of guessing. Can you share the .skp file so we can see what you have set up already?
        Are you still using SketchUp 8? If not, please update your profile so it is correct.
          Like a "snake" with a constant diameter size ?
            I'm guessing like a footpath on a globe or the pattern on a tennis ball.
            • R
              RHA57
              sorry guys,
              Bad weather here, i had to switch off every electrical device...
              YESSSS
              Tell me now you can help me ;o)
                Use Follow Me.
                Share your SKP file so we can see what you are trying to accomplish.
                • david_hD
                  david_h
                  there's also a plugin called Pipe Along Path. but that's just for round-y things. if you are doing a conplicated shape. . .follow me is best.
                    Draw a circle on the ground
                    Draw any 3D curve from the center of the Circle
                    First segment of the curve must be perpendicular to the Curve!
                    Click the Curve
                    Click the Follow me Tool
                    Click the Surface of the Circle
                    • R
                      RHA57
                      So here's my skp file, you can see the big circle with 3 three-quarters circles in it and a small circle on the right.
                      I want to "dig" the big circle with the shape of the small circle on the right from the center of the big circle to the border of this one.
                      Thanks again guys
                      test.skp
                      • R
                        RHA57
                        i want to do something like that but something more smooth with a circle shape to dig....
                        It's like a "bold" three-quarter circle...
                        test2.skp
                          I don't understand what you mean by "dig". Is this the sort of thing you are after?
                          • R
                            RHA57
                            So i did it manually with the offset tool , i had to extend the lines by myself ...so it's not using the small circle as a shape to "dig", to remove from the surface...
                            I m sure there is a better way to do that...
                            test3.skp
                            test4.skp
                              I believe the word you want is to 'Etch'. "To scribe a line, curve or shape on a surface".
                                So you want to create spaces between the sectors that are as wide as the circle? There's no "dig" involved. Offset is a good option for this. Yes, you will have to add an edge segment on one curve and delete one on the other curve.
                                One of your curves is not the same shape/orientation as the others. It's shown selected.
                                I I wanted to model something like this I'd make it easier by leveraging Copy/Rotate.
                                Click on the picture
                                • R
                                  RHA57
                                  I see, thanks i will do it like that...
                                  Thank you guys...
                                  Such a great community here
                                  Take care of yourself
