    FredoCorner: Invalid no match of edge properties
    4 Posts 3 Posters 5.1k Views 3 Watching
    • Z
      ZioMauri
      I used FredoCorner tool for a while without any issue.
      Now, when i tried to use it again, i received the following message: "Invalid no match of edge properties".
      I tried resetting every extension option to default, started a new project with only a cube drawed, but no way, just the same error.
      Upgrading Extension and Libraries to the last version didn't solved the issue.
      So i tried to install and use Round Corners on the same cube, and it worked fine.
      Am I missing someting?
      • TIGT
        Post the problem SKP with details of the steps you follow using the extension - plus images where appropriate.
        Without it we are all guessing - help us to help you...
        • fredo6F
          fredo6
          This is most probably due to the settings of the Edge property filters. Just check the right options.
          Fredo
          • Z
            ZioMauri
            [attachment=0:323gg2mk]<!-- ia0 -->FredoCorner Filter edges.png<!-- ia0 -->[/attachment:323gg2mk]
            Fredo
            You got it! πŸ‘
