    Junji Okubo Scout 23GN
    23 Posts 4 Posters 6.9k Views 4 Watching
    • Bryan KB Offline
      Robot number two. Scout 23GN.
      Using the previous designed chassis.
      Very, very rough block out of the legs.
      • Bryan KB Offline
        Roughing out the legs and making sure the proportions are right before starting the details.
        • Bryan KB Offline
          Rough out of upper body proportions and shape.
          Again, VERY rough.
          • Bryan KB Offline
            Still roughing out scales and proportions.
            Center chassis has not been touched or changed.
              I like where this is going, wheels, well it would be very handy for the weekly outing to the supermarket for a start.
              • Bryan KB Offline
                As always, thanks Mike. πŸ‘
                • Bryan KB Offline
                  Fairly happy with the leg proportions, so I've started on the details.
                  • hellnbakH Offline
                    hellnbak
                    Nice work, Bryan.
                    What's the purpose of the safety cone? To signify that the work is under construction?
                    • Bryan KB Offline
                      @hellnbak said:
                      Nice work, Bryan.
                      Thanks!
                      I'm using the safety cone to create and show scale. It's from the original spider robot artist's drawings, so I included it to get approximate scale when I did the spider robot model and it's just carried over.
                      • Bryan KB Offline
                        More leg details. One last block to detail.
                        Lots and lots of fiddling.
                        • Bryan KB Offline
                          Wheel details completed.
                          One last detail block on the leg to finish. I can't wait to finish it because there is one more trick to the legs.
                          • Bryan KB Offline
                            For some reason groups and components went crazy. I must have accidentally moved things into other components.
                            Anyway, the legs are finished except for the connecting axles to the chassis.
                            YAH!
                            Again, it's not exactly like the reference drawings, but it very, very close. And considering the reference drawing aren't consistent either (and some are even fuzzy), this is close enough.
                            • Bryan KB Offline
                              Legs completed and positioned at angle.
                              Upper body roughed in for proportions. It will change a lot before it's finished.
                              • tuna1957T Offline
                                tuna1957
                                Looking great πŸ‘
                                • Bryan KB Offline
                                  Thanks tuna!
                                    Lots of lovely detail, it's a cracking model mate.
                                    • Bryan KB Offline
                                      • Bryan KB Offline
                                        PHEW! What a pain. It took me a long time to figure out the upper body shape because the artist drew it with "impossible" angles.
                                        I show the hidden lines in the last picture to demonstrate all the lines I needed to make to get the angled planes to create faces. I then Shift-E erased them to get the smoothed body.
                                        I can now start detailing the upper body.
                                        This will have to do to. Again, it's not exactly like the drawing but it's very close.
                                        • Bryan KB Offline
                                          Edge beveling on upper body completed. Partly bevel tool, partly by hand to reconnect the faces where it broke on the curves.
                                          Antenna added.
                                          • Bryan KB Offline
                                            Starting the front details.
                                            • 1 / 2
