    Junji Okubo Scout 23GN
    23 Posts 4 Posters 7.6k Views 4 Watching
    • Bryan KB
      Fairly happy with the leg proportions, so I've started on the details.
      • hellnbakH
        hellnbak
        Nice work, Bryan.
        What's the purpose of the safety cone? To signify that the work is under construction?
        • Bryan KB
          @hellnbak said:
          Nice work, Bryan.
          I'm using the safety cone to create and show scale. It's from the original spider robot artist's drawings, so I included it to get approximate scale when I did the spider robot model and it's just carried over.
          • Bryan KB
            More leg details. One last block to detail.
            Lots and lots of fiddling.
            • Bryan KB
              Wheel details completed.
              One last detail block on the leg to finish. I can't wait to finish it because there is one more trick to the legs.
              • Bryan KB
                For some reason groups and components went crazy. I must have accidentally moved things into other components.
                Anyway, the legs are finished except for the connecting axles to the chassis.
                YAH!
                Again, it's not exactly like the reference drawings, but it very, very close. And considering the reference drawing aren't consistent either (and some are even fuzzy), this is close enough.
                • Bryan KB
                  Legs completed and positioned at angle.
                  Upper body roughed in for proportions. It will change a lot before it's finished.
                  • tuna1957T
                    tuna1957
                    Looking great πŸ‘
                    • Bryan KB
                      Thanks tuna!
                        Lots of lovely detail, it's a cracking model mate.
                        • Bryan KB
                          As always, thanks Mike.
                          • Bryan KB
                            PHEW! What a pain. It took me a long time to figure out the upper body shape because the artist drew it with "impossible" angles.
                            I show the hidden lines in the last picture to demonstrate all the lines I needed to make to get the angled planes to create faces. I then Shift-E erased them to get the smoothed body.
                            I can now start detailing the upper body.
                            This will have to do to. Again, it's not exactly like the drawing but it's very close.
                            • Bryan KB
                              Edge beveling on upper body completed. Partly bevel tool, partly by hand to reconnect the faces where it broke on the curves.
                              Antenna added.
                              • Bryan KB
                                Starting the front details.
                                • Bryan KB
                                  It's almost finished.
                                  • Bryan KB
                                    And DONE!
                                    Yay!
                                    I will set in final scene and post on main gallery page.
                                    On to the next one!
                                    • Bryan KB
                                      The rear is complete. Now to just finished the top.
                                      Moved the rear cylinders down to make room for the tail lights.
