    Junji Okubo Scout 23GN
    23 Posts 4 Posters 7.3k Views 4 Watching
    • Bryan KB Offline
      Rough out of upper body proportions and shape.
      Again, VERY rough.
      • Bryan KB Offline
        Still roughing out scales and proportions.
        Center chassis has not been touched or changed.
          I like where this is going, wheels, well it would be very handy for the weekly outing to the supermarket for a start.
          • Bryan KB Offline
            As always, thanks Mike. πŸ‘
            • Bryan KB Offline
              Fairly happy with the leg proportions, so I've started on the details.
              • hellnbakH Offline
                hellnbak
                Nice work, Bryan.
                What's the purpose of the safety cone? To signify that the work is under construction?
                • Bryan KB Offline
                  @hellnbak said:
                  Nice work, Bryan.
                  I'm using the safety cone to create and show scale. It's from the original spider robot artist's drawings, so I included it to get approximate scale when I did the spider robot model and it's just carried over.
                  • Bryan KB Offline
                    More leg details. One last block to detail.
                    Lots and lots of fiddling.
                    • Bryan KB Offline
                      Wheel details completed.
                      One last detail block on the leg to finish. I can't wait to finish it because there is one more trick to the legs.
                      • Bryan KB Offline
                        For some reason groups and components went crazy. I must have accidentally moved things into other components.
                        Anyway, the legs are finished except for the connecting axles to the chassis.
                        YAH!
                        Again, it's not exactly like the reference drawings, but it very, very close. And considering the reference drawing aren't consistent either (and some are even fuzzy), this is close enough.
                        • Bryan KB Offline
                          Legs completed and positioned at angle.
                          Upper body roughed in for proportions. It will change a lot before it's finished.
                          • tuna1957T Online
                            tuna1957
                            Looking great πŸ‘
                            • Bryan KB Offline
                              Thanks tuna!
                                Lots of lovely detail, it's a cracking model mate.
                                • Bryan KB Offline
                                  • Bryan KB Offline
                                    PHEW! What a pain. It took me a long time to figure out the upper body shape because the artist drew it with "impossible" angles.
                                    I show the hidden lines in the last picture to demonstrate all the lines I needed to make to get the angled planes to create faces. I then Shift-E erased them to get the smoothed body.
                                    I can now start detailing the upper body.
                                    This will have to do to. Again, it's not exactly like the drawing but it's very close.
                                    • Bryan KB Offline
                                      Edge beveling on upper body completed. Partly bevel tool, partly by hand to reconnect the faces where it broke on the curves.
                                      Antenna added.
                                      • Bryan KB Offline
                                        Starting the front details.
                                        • Bryan KB Offline
                                          It's almost finished.
                                          • Bryan KB Offline
                                            And DONE!
                                            Yay!
                                            I will set in final scene and post on main gallery page.
                                            On to the next one!
