    [Plugin][$] FredoSpline - v2.6a - 01 Apr 24
    149 Posts 40 Posters 198.1k Views 40 Watching
    • A
      apodsim
      I am having difficulty accessing the "Instructor window accessible from within the extension" refenced in YouTube and SkechUcation for FedoSpline version 2.4. Is this a add-in or am I missing something?
        @apodsim said:
        I am having difficulty accessing the "Instructor window accessible from within the extension"...
        This is what I'm seeing with the Instructor panel open.
        Click on the picture
        What version of SketchUp are you using? What operating system? Please complete your forum profile. That information helps us help you.
        • X
          xyhcwu
          I updated the version, but it prompts the following dialog, how can I make it work?
          Error in the License Validation
          Response from Sketchucation: License seats exceeded.
            Make sure the Sketchucation Tool is also up to date and then go into Tools>Fredo6 Collection>FredoSpline>License and release seats.
            What version of SketchUp are you actually using? Your profile indicates a version that has never existed.
            • fredo6F
              fredo6
              As said in a PM I sent you, you need to release at least one seat. You have 3 taken currently.
              • X
                xyhcwu
                I've been using it on one of my own computers since I purchased the license, but every time I update it, it always tells me I need to activate it. After this update , it doesn't work, what am I doing wrong?
                  Again, what version of SketchUp are you using? There is no 2020 Free/Make version.
                  Did you correctly install whatever version you are using? On Windows that requires right clicking on the download installer and selecting Run as administrator. If you didn't do that Windows security can prevent required files from being written. Quit SketchUp, find the SketchUp installer, right click on it, choose Run as administrator, and when it is presented, choose Repair.
                  • X
                    xyhcwu
                    I have only SketchUp 2020 installed and I use a vpn proxy to access the internet, I don't know if it has any effect. I will try your method, thank you!
                      @xyhcwu said:
                      I have only SketchUp 2020 installed ...
                      So SketchUp Pro. Please correct your profile.
                      It certainly could.
                      • R
                        rv1974
                        Fredo, In SU 2023, latest lib and FredoSpline..
                        I have problems with Convert command inside context it olny shows preview but doesn't allow to convert and exit. It works as expected if the same geometry is placed out of context. I PM you some example. Could you fix it please?
                        Yet another problem (not new one): Curves from FredoSpline can't serve as paths for Profile Builder Assemblies (unfortunately they need to be exploded), but do work with PB profiles.
                        • R
                          rv1974
                          Could anybody try Convert tool inside context in v2023 please? Is it working for you?
                          This function is too important for me so I have to get back to 2022.
                          • fredo6F
                            fredo6
                            It works for me.
                            Could you open the Ruby Console before launching the conversion, in case there are error messages.
                            EDIT: I found the error, and this is specific to SU2023. It works in SU2022 as you mentioned. I need to investigate...
                            • fredo6F
                              fredo6
                              NEW RELEASE: FredoSpline v2.5a - 01 Mar 23
                              Requirements
                              • LibFredo6: v13.6a
                              FredoSpline 2.5a fixes a weird issue specific to SU2023 related to Convert Curve within a context
                              Home Page of FredoSpline for information and Download.
                              Main post of this FredoSpline thread.
                              • R
                                rv1974
                                Huge news thank you so much Fredo!
                                • fredo6F
                                  fredo6
                                  The issue was signaled during the Beta testing but was not fixed in the release (among other issues and bugs).
                                  • R
                                    rv1974
                                    Another thing.. Grouping curves generated with FS turn them into regular dumb curves (for example it's not possible to edit the filets anymore). Is it possible to preserve FredoSpline properties inside group?
                                    • R
                                      rv1974
                                      Do you think this bug potentially could lead to the Drape tool stop working inside context?
                                      • fredo6F
                                        fredo6
                                        It is fairly possible... SandBox is an extension and can be affected the same way as other plugins. The bug introduced in SU2023 could affect many plugins actually.
                                        Just open the Ruby Console when you play with the Drape Tool. if you see traces with erase_entities, then it is the same problem. Fortunately, there is a workaround and I guess the Sketchup team should fix it without waiting for the next version of SU2023.
                                        • fredo6F
                                          fredo6
                                          Do you have an example of that. I am not sure I understand.
                                          • R
                                            rv1974
                                            Never mind its not an issue anymore in present version. sorry for bothering
                                            • 6
                                            • 7
                                            • 8
                                            • 6 / 8
