    [Plugin][$] FredoSpline - v2.6a - 01 Apr 24
    149 Posts 40 Posters 193.5k Views 40 Watching
      rv1974
      Yu can act on several control points of one spline curve...
      Thanks for info I didn't know it's possible to select several points with control key pressed.
      And is it possible to add selecting with crossing window?
      It would complex and prone to side-effects to edit multiple curves at the same time.
      Too bad.. it's very limitating
      • fredo6F Offline
        NEW RELEASE: FredoSpline v2.4a - 25 Dec 22
        Requirements
        • LibFredo6: v13.6a
        FredoSpline 2.4a is a maintenance release for extension of validity
        Home Page of FredoSpline for information and Download.
        Main post of this FredoSpline thread.
          apodsim
          I am having difficulty accessing the "Instructor window accessible from within the extension" refenced in YouTube and SkechUcation for FedoSpline version 2.4. Is this a add-in or am I missing something?
            @apodsim said:
            I am having difficulty accessing the "Instructor window accessible from within the extension"...
            This is what I'm seeing with the Instructor panel open.
            Click on the picture
            What version of SketchUp are you using? What operating system? Please complete your forum profile. That information helps us help you.
            • X Offline
              xyhcwu
              I updated the version, but it prompts the following dialog, how can I make it work?
              Error in the License Validation
              Response from Sketchucation: License seats exceeded.
                Make sure the Sketchucation Tool is also up to date and then go into Tools>Fredo6 Collection>FredoSpline>License and release seats.
                What version of SketchUp are you actually using? Your profile indicates a version that has never existed.
                • fredo6F Offline
                  As said in a PM I sent you, you need to release at least one seat. You have 3 taken currently.
                  • X Offline
                    xyhcwu
                    I've been using it on one of my own computers since I purchased the license, but every time I update it, it always tells me I need to activate it. After this update , it doesn't work, what am I doing wrong?
                      Again, what version of SketchUp are you using? There is no 2020 Free/Make version.
                      Did you correctly install whatever version you are using? On Windows that requires right clicking on the download installer and selecting Run as administrator. If you didn't do that Windows security can prevent required files from being written. Quit SketchUp, find the SketchUp installer, right click on it, choose Run as administrator, and when it is presented, choose Repair.
                      • X Offline
                        xyhcwu
                        I have only SketchUp 2020 installed and I use a vpn proxy to access the internet, I don't know if it has any effect. I will try your method, thank you!
                          @xyhcwu said:
                          I have only SketchUp 2020 installed ...
                          So SketchUp Pro. Please correct your profile.
                          It certainly could.
                            rv1974
                            Fredo, In SU 2023, latest lib and FredoSpline..
                            I have problems with Convert command inside context it olny shows preview but doesn't allow to convert and exit. It works as expected if the same geometry is placed out of context. I PM you some example. Could you fix it please?
                            Yet another problem (not new one): Curves from FredoSpline can't serve as paths for Profile Builder Assemblies (unfortunately they need to be exploded), but do work with PB profiles.
                              rv1974
                              Could anybody try Convert tool inside context in v2023 please? Is it working for you?
                              This function is too important for me so I have to get back to 2022.
                              • fredo6F Offline
                                It works for me.
                                Could you open the Ruby Console before launching the conversion, in case there are error messages.
                                EDIT: I found the error, and this is specific to SU2023. It works in SU2022 as you mentioned. I need to investigate...
                                • fredo6F Offline
                                  NEW RELEASE: FredoSpline v2.5a - 01 Mar 23
                                  Requirements
                                  • LibFredo6: v13.6a
                                  FredoSpline 2.5a fixes a weird issue specific to SU2023 related to Convert Curve within a context
                                    rv1974
                                    Huge news thank you so much Fredo!
                                    • fredo6F Offline
                                      The issue was signaled during the Beta testing but was not fixed in the release (among other issues and bugs).
                                        rv1974
                                        Another thing.. Grouping curves generated with FS turn them into regular dumb curves (for example it's not possible to edit the filets anymore). Is it possible to preserve FredoSpline properties inside group?
                                          rv1974
                                          Do you think this bug potentially could lead to the Drape tool stop working inside context?
                                          • fredo6F Offline
                                            It is fairly possible... SandBox is an extension and can be affected the same way as other plugins. The bug introduced in SU2023 could affect many plugins actually.
                                            Just open the Ruby Console when you play with the Drape Tool. if you see traces with erase_entities, then it is the same problem. Fortunately, there is a workaround and I guess the Sketchup team should fix it without waiting for the next version of SU2023.
                                            • 6 / 8
