    [Plugin][$] FredoSpline - v2.6a - 01 Apr 24
    149 Posts 40 Posters 195.5k Views 40 Watching
    • fredo6F
      @xyhcwu said:
      I updated the version, but it prompts the following dialog, how can I make it work?
      Error in the License Validation
      Response from Sketchucation: License seats exceeded.
      As said in a PM I sent you, you need to release at least one seat. You have 3 taken currently.
      • X
        xyhcwu
        I've been using it on one of my own computers since I purchased the license, but every time I update it, it always tells me I need to activate it. After this update , it doesn't work, what am I doing wrong?
          Again, what version of SketchUp are you using? There is no 2020 Free/Make version.
          Did you correctly install whatever version you are using? On Windows that requires right clicking on the download installer and selecting Run as administrator. If you didn't do that Windows security can prevent required files from being written. Quit SketchUp, find the SketchUp installer, right click on it, choose Run as administrator, and when it is presented, choose Repair.
          • X
            xyhcwu
            I have only SketchUp 2020 installed and I use a vpn proxy to access the internet, I don't know if it has any effect. I will try your method, thank you!
              @xyhcwu said:
              I have only SketchUp 2020 installed ...
              So SketchUp Pro. Please correct your profile.
              It certainly could.
                rv1974
                Fredo, In SU 2023, latest lib and FredoSpline..
                I have problems with Convert command inside context it olny shows preview but doesn't allow to convert and exit. It works as expected if the same geometry is placed out of context. I PM you some example. Could you fix it please?
                Yet another problem (not new one): Curves from FredoSpline can't serve as paths for Profile Builder Assemblies (unfortunately they need to be exploded), but do work with PB profiles.
                  rv1974
                  Could anybody try Convert tool inside context in v2023 please? Is it working for you?
                  This function is too important for me so I have to get back to 2022.
                  • fredo6F
                    It works for me.
                    Could you open the Ruby Console before launching the conversion, in case there are error messages.
                    EDIT: I found the error, and this is specific to SU2023. It works in SU2022 as you mentioned. I need to investigate...
                    • fredo6F
                      NEW RELEASE: FredoSpline v2.5a - 01 Mar 23
                      Requirements
                      • LibFredo6: v13.6a
                      FredoSpline 2.5a fixes a weird issue specific to SU2023 related to Convert Curve within a context
                      Home Page of FredoSpline for information and Download.
                      Main post of this FredoSpline thread.
                        rv1974
                        Huge news thank you so much Fredo!
                        • fredo6F
                          The issue was signaled during the Beta testing but was not fixed in the release (among other issues and bugs).
                            rv1974
                            Another thing.. Grouping curves generated with FS turn them into regular dumb curves (for example it's not possible to edit the filets anymore). Is it possible to preserve FredoSpline properties inside group?
                              rv1974
                              Do you think this bug potentially could lead to the Drape tool stop working inside context?
                              • fredo6F
                                It is fairly possible... SandBox is an extension and can be affected the same way as other plugins. The bug introduced in SU2023 could affect many plugins actually.
                                Just open the Ruby Console when you play with the Drape Tool. if you see traces with erase_entities, then it is the same problem. Fortunately, there is a workaround and I guess the Sketchup team should fix it without waiting for the next version of SU2023.
                                • fredo6F
                                  Do you have an example of that. I am not sure I understand.
                                    rv1974
                                    Never mind its not an issue anymore in present version. sorry for bothering
                                      rv1974
                                      I'd love to see those reports, was it opened discussion?
                                        rv1974
                                        Well I tested the latest FredoSpline in v2023 unfortunately almost everything is broken (in context): Edit, Swap etc. This is the worst SU release ever since v2 😕 . Tons of crashes on start and during all sorts of procedures. Will have to get back to v2022 till they'd sort it out
                                          I'm not having any crashes of SU2023 at all. It's been very stable for me.
                                          • jenujacobJ
                                            jenujacob
                                            Hi Fredo..
                                            i just updated the libfredo and fredo spline now and since then i am unable to open the quick launchers of Fredo spline, joint push pull, fredo scale and the check fredo6 plugins for update menu. attaching the error in the rubby console below.
                                            Error; #<NoMethodError; undefined method `wdlg_from_key' for Traductor;;Wdlg;Class>
                                            c;/users/jenu v jacob/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6webwdlg.rbe;37;in `check_instance_displayed'
                                            c;/users/jenu v jacob/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6quicklauncher.rbe;42;in `invoke'
                                            c;/users/jenu v jacob/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_fredospline/bootstrap_fredospline.rbe;213;in `invoke_quick_launcher'
                                            c;/users/jenu v jacob/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_fredospline/bootstrap_fredospline.rbe;268;in `launch'
                                            c;/users/jenu v jacob/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_fredospline/bootstrap_fredospline.rbe;250;in `action__mapping'
                                            c;/users/jenu v jacob/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe;143;in `call'
                                            c;/users/jenu v jacob/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe;143;in `launch_action'
                                            c;/users/jenu v jacob/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe;240;in `launch_action'
                                            c;/users/jenu v jacob/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_fredospline/bootstrap_fredospline.rbe;120;in `launch_action'
                                            c;/users/jenu v jacob/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_fredospline/bootstrap_fredospline.rbe;133;in `block in startup'
                                            c;/users/jenu v jacob/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe;1469;in `command_invoke'
                                            c;/users/jenu v jacob/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe;1449;in `block (2 levels) in build_config_commands'
                                            c;/users/jenu v jacob/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6traductor.rbe;1385;in `block in add_command'
                                            • 6 / 8
