    [Plugin][$] FredoSpline - v2.6a - 01 Apr 24
    149 Posts 40 Posters 182.3k Views 40 Watching
    • ArcA Offline
      Arc
      Convert Curves Error.
      Error; #<TypeError; no implicit conversion of nil into Hash>
      c;/users/xwtao/appdata/roaming/sketchup/sketchup 2019/sketchup/plugins/fredo6_fredospline/fredosplinetool.rbe;5847;in `update'
      c;/users/xwtao/appdata/roaming/sketchup/sketchup 2019/sketchup/plugins/fredo6_fredospline/fredosplinetool.rbe;5847;in `edge_picking_init'
      c;/users/xwtao/appdata/roaming/sketchup/sketchup 2019/sketchup/plugins/fredo6_fredospline/fredosplinetool.rbe;244;in `initialize'
      c;/users/xwtao/appdata/roaming/sketchup/sketchup 2019/sketchup/plugins/fredo6_fredospline/bootstrap_fredospline.rbe;291;in `new'
      c;/users/xwtao/appdata/roaming/sketchup/sketchup 2019/sketchup/plugins/fredo6_fredospline/bootstrap_fredospline.rbe;291;in `launch'
      c;/users/xwtao/appdata/roaming/sketchup/sketchup 2019/sketchup/plugins/fredo6_fredospline/bootstrap_fredospline.rbe;245;in `action__mapping'
      c;/users/xwtao/appdata/roaming/sketchup/sketchup 2019/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe;126;in `call'
      c;/users/xwtao/appdata/roaming/sketchup/sketchup 2019/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe;126;in `launch_action'
      c;/users/xwtao/appdata/roaming/sketchup/sketchup 2019/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe;224;in `launch_action'
      c;/users/xwtao/appdata/roaming/sketchup/sketchup 2019/sketchup/plugins/fredo6_fredospline/bootstrap_fredospline.rbe;118;in `launch_action'
      c;/users/xwtao/appdata/roaming/sketchup/sketchup 2019/sketchup/plugins/fredo6_fredospline/bootstrap_fredospline.rbe;183;in `block in declare_command'
      c;/users/xwtao/appdata/roaming/sketchup/sketchup 2019/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe;1321;in `command_invoke'
      c;/users/xwtao/appdata/roaming/sketchup/sketchup 2019/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe;1303;in `block (2 levels) in build_config_commands'
      c;/users/xwtao/appdata/roaming/sketchup/sketchup 2019/sketchup/plugins/fredo6_!libfredo6/lib6traductor.rbe;1372;in `block in add_command'
      • fredo6F Offline
        fredo6
        @Arc
        Did you update to FredoSpline v1.2a?
        The error lines seems outdated.
        Fredo
        • ArcA Offline
          Arc
          It is fixed, thank you.
            reza1813
            Dear Fredo,
            Hello, is it any possibility to add Gumball to Fredospline like the Rhino? I know that we have it now in these plugins, but regarding the graphical concern, it would be great when we select the point, then we can see a Gumball on top of the point. Thanks.
            • fredo6F Offline
              fredo6
              @reza1813 said:
              Dear Fredo,
              You have the direction inferences on axes (global and local), you can also lock any direction. And once the direction is locked or inferred, you can type a distance.
              The interest of the gumball (as I see it in the other software) is that you can select several control points (via a selection rectangle) and move them together.
              • PixeroP Offline
                Pixero
                I have always wanted a bezier tool in SketchUp that behaves like in 2D vector programs such as Freehand or Affinity Designer.
                Here is an old little test I did with paperjs where I made a simple drawing tool in the browser.
                Click to create straight lines. Click and hold and drag to create smooth corners.
                What I like is the control and the preview of the next curve segment before you click to place it.
                Close the curve to create a new curve.
                (In this little test you can't go back and edit already made curves.)
                Bezier Pen Tool
                (pixero.com)
                This is exactly like how it works in for example Freehand (Which in my humble opinion was a much better vector program than Illustrator before Adobe bought and killed it.)
                Would it be possible with FredoSpline?
                  rv1974
                  @Pixero:
                  This is what I suggested: single click for Corner, click & drag for Bezier Smooth, Backspace for last input Undo. Rather standard cross platform behavior.
                  • fredo6F Offline
                    fredo6
                    NEW RELEASE: FredoSpline v1.3a - 25 May 20
                    Requirements
                    • LibFredo6: v10.5a
                    FredoSpline 1.3a is a maintenance release for bug fixing and cosmetic adjustments for Mac
                    Home Page of FredoSpline for information and Download.
                    Main post of this FredoSpline thread.
                    • fredo6F Offline
                      fredo6
                      NEW RELEASE: FredoSpline v1.4a - 01 Jun 20
                      Requirements
                      • LibFredo6: v10.6a
                      FredoSpline 1.4a is a maintenance release for bug fixing and cosmetic adjustments for Mac
                      • G Offline
                        Gray Gardner
                        File won't seem to install in my sketchup. "failed to install FredoSpline_v1.4a.rbz"
                        • fredo6F Offline
                          fredo6
                          Difficult to help without more information....
                          • fredo6F Offline
                            fredo6
                            NEW RELEASE: FredoSpline v1.5a - 19 Aug 20
                            Requirements
                            • LibFredo6: v11.0a
                            FredoSpline 1.5a is a maintenance release for cosmetic adjustments and extension of validity
                              rv1974
                              Fredo, is Covert curves command able to alter radius of already existing fillets (in polycorner arc curve)? Or at least remove all fillets (= radius 0)?
                              • fredo6F Offline
                                fredo6
                                If you wish to remove all fillets, then SWAP it to Polyline.
                                Remember the difference between Edit, Swap and Convert:
                                EDIT allows to change the parameters (as well as control points) of a single existing FredoSpline curve. Actually, you can also change the type.
                                • SWAPchanges the type of an existing FredoSpline curve. The benefit of Swap is that you can preselect several curves
                                • CONVERTis used to make a FredoSpline curve of a given type from one or several non-FredoSpline sequences of segments. Indeed, it also works with a FredoSpline curves; in which case, it would be equivalent to Swap.
                                  rv1974
                                  thank you for clarification, Swap function is divine as well as all toolset ☀
                                    Michelfad
                                    HOW TO UPDATE FOR THE LATEST VERSION
                                      rv1974
                                      Fredo, here is a small but important suggestion:
                                      When editing* polycorner's fillets with mouse scrolling (or slider) it'd be great to have ability to snap to user defined rounding values (like 10\50\100 cm)
                                      It could be implemented by continuously pressing one of modifier keys while scrolling
                                      *- Usually people work with 2+ digits after point precision, and using mouse scroll\slider nowdelivers bad radius values.
                                      Thank you for attention
                                      • fredo6F Offline
                                        fredo6
                                        Maybe I'll add an explicit configuration parameter, because there are issues with guessing the right increment:
                                        1. imperial and other exotic units could be used
                                        2. the order of magnitude is difficult to infer, as curves are drawn outside of context. You wish 10/50/100 cm, but another user may want 10/50/100 m)
                                          rv1974
                                          BTW For some reason Profile Builders assemblies don't like closed polyacrc curves- they need to be converted to regular polylines (or exploded) in order to be treated as paths
                                          • fredo6F Offline
                                            fredo6
                                            I don't have Profile Builder installed. This is strange, because FredoSpline generate geometry as true Sketchup curves, with some extra attributes. So, it should be transparent to Profile Builder.
                                            The problem with closed curves is the start point of the curve, which may not be what you would visually expect.
                                            • 6
                                            • 7
                                            • 8
                                            • 2 / 8
