    [Plugin][$] FredoSpline - v2.6a - 01 Apr 24
    149 Posts 40 Posters 201.1k Views 40 Watching
    • fredo6F
      @Arc
      Did you update to FredoSpline v1.2a?
      The error lines seems outdated.
      • ArcA
        Arc
        It is fixed, thank you.
          reza1813
          Dear Fredo,
          Hello, is it any possibility to add Gumball to Fredospline like the Rhino? I know that we have it now in these plugins, but regarding the graphical concern, it would be great when we select the point, then we can see a Gumball on top of the point. Thanks.
          • fredo6F
            @reza1813 said:
            Dear Fredo,
            You have the direction inferences on axes (global and local), you can also lock any direction. And once the direction is locked or inferred, you can type a distance.
            The interest of the gumball (as I see it in the other software) is that you can select several control points (via a selection rectangle) and move them together.
            • PixeroP
              Pixero
              I have always wanted a bezier tool in SketchUp that behaves like in 2D vector programs such as Freehand or Affinity Designer.
              Here is an old little test I did with paperjs where I made a simple drawing tool in the browser.
              Click to create straight lines. Click and hold and drag to create smooth corners.
              What I like is the control and the preview of the next curve segment before you click to place it.
              Close the curve to create a new curve.
              (In this little test you can't go back and edit already made curves.)
              No website is present on this hostname
              The website you are trying to reach could be suspended, deleted or DNS could be incorrect
              (pixero.com)
              This is exactly like how it works in for example Freehand (Which in my humble opinion was a much better vector program than Illustrator before Adobe bought and killed it.)
              Would it be possible with FredoSpline?
                rv1974
                @Pixero:
                This is what I suggested: single click for Corner, click & drag for Bezier Smooth, Backspace for last input Undo. Rather standard cross platform behavior.
                • fredo6F
                  NEW RELEASE: FredoSpline v1.3a - 25 May 20
                  Requirements
                  • LibFredo6: v10.5a
                  FredoSpline 1.3a is a maintenance release for bug fixing and cosmetic adjustments for Mac
                  Home Page of FredoSpline for information and Download.
                  Main post of this FredoSpline thread.
                  • fredo6F
                    NEW RELEASE: FredoSpline v1.4a - 01 Jun 20
                    Requirements
                    • LibFredo6: v10.6a
                    FredoSpline 1.4a is a maintenance release for bug fixing and cosmetic adjustments for Mac
                    • G
                      Gray Gardner
                      File won't seem to install in my sketchup. "failed to install FredoSpline_v1.4a.rbz"
                      • fredo6F
                        Difficult to help without more information....
                        • fredo6F
                          NEW RELEASE: FredoSpline v1.5a - 19 Aug 20
                          Requirements
                          • LibFredo6: v11.0a
                          FredoSpline 1.5a is a maintenance release for cosmetic adjustments and extension of validity
                            rv1974
                            Fredo, is Covert curves command able to alter radius of already existing fillets (in polycorner arc curve)? Or at least remove all fillets (= radius 0)?
                            • fredo6F
                              If you wish to remove all fillets, then SWAP it to Polyline.
                              Remember the difference between Edit, Swap and Convert:
                              EDIT allows to change the parameters (as well as control points) of a single existing FredoSpline curve. Actually, you can also change the type.
                              • SWAPchanges the type of an existing FredoSpline curve. The benefit of Swap is that you can preselect several curves
                              • CONVERTis used to make a FredoSpline curve of a given type from one or several non-FredoSpline sequences of segments. Indeed, it also works with a FredoSpline curves; in which case, it would be equivalent to Swap.
                                rv1974
                                thank you for clarification, Swap function is divine as well as all toolset ☀
                                  Michelfad
                                  HOW TO UPDATE FOR THE LATEST VERSION
                                    rv1974
                                    Fredo, here is a small but important suggestion:
                                    When editing* polycorner's fillets with mouse scrolling (or slider) it'd be great to have ability to snap to user defined rounding values (like 10\50\100 cm)
                                    It could be implemented by continuously pressing one of modifier keys while scrolling
                                    *- Usually people work with 2+ digits after point precision, and using mouse scroll\slider nowdelivers bad radius values.
                                    Thank you for attention
                                    • fredo6F
                                      Maybe I'll add an explicit configuration parameter, because there are issues with guessing the right increment:
                                      1. imperial and other exotic units could be used
                                      2. the order of magnitude is difficult to infer, as curves are drawn outside of context. You wish 10/50/100 cm, but another user may want 10/50/100 m)
                                        rv1974
                                        BTW For some reason Profile Builders assemblies don't like closed polyacrc curves- they need to be converted to regular polylines (or exploded) in order to be treated as paths
                                        • fredo6F
                                          I don't have Profile Builder installed. This is strange, because FredoSpline generate geometry as true Sketchup curves, with some extra attributes. So, it should be transparent to Profile Builder.
                                          The problem with closed curves is the start point of the curve, which may not be what you would visually expect.
                                          • fredo6F
                                            NEW RELEASE: FredoSpline v1.6a - 19 Nov 20
                                            Requirements
                                            • LibFredo6: v11.3a
                                            FredoSpline 1.6a is a maintenance release for
                                            • Help can be accessed in a separate window, not just the Instructor
                                            • Extension of validity
                                            • 2 / 8
