    Problem with Sketchucation downloads
    3 Posts 3 Posters 1.1k Views 3 Watching
    • I Offline
      iworkwood
      Any plugin-extension that I download from any site other than the extension manager tries to pen as a Sketchup file and crashes Sketchup. Why?
        Are you doing anything with the file after downloading it?
        Are you using SketchUp 2014 as indicated in your profile?
          Your web-browser has many settings/options.
          For each file-type download made through your web-browser you can/must set an action...
          So for example, for a PDF file you might specify to always open it with the associated PDF-app...
          For a SKP file you might specify to either open if [with SketchUp using a Temp-file download] or to Save it directly to your computer - with no 'open'...
          For an RBZ [which is an extension archive] you should always have it set to Save... and nothing more...
          For the Saving location you can specify [say] to use your 'Downloads' folder, or 'Ask for location' each time...
          It sounds like your browser-settings have RBZ associated with SketchUp [incorrectly] and so it tries to open it after it is downloaded, and thereby breaks SketchUp doing.
          You need to Save it, and then use the built-in SketchUp > Extension-Manager to 'Install' the RBZ for you...
          So change your web-browser's settings/options to save the RBZ, NOT to open it...
          Then retry getting an RBZ downloaded... and then installed...
