    Face and Shape of Specific Area
    12 Posts 2 Posters 1.8k Views 2 Watching
    • B
      Ben Ritter
      Is there a way to create a face with a specific area? I'd like to draw circles or polygons with a specific area.
      Thanks.
      • TIGT
        https://sketchucation.com/pluginstore?pln=TIG_scale_face
        Draw a the desired face shape [it can be any size], select that face and then activate the tool.
        The face's initial area is reported in a dialog, type in the desired target area, then OK - the face is then rescaled to have the desired target area...
        • B
          Ben Ritter
          TIG, thanks so much.
          • B
            Ben Ritter
            TIG, tried it and it doesn't scale properly. Working in sq. ft. units.
            Thanks. Ben
            • TIGT
              Bum !
              I'll look at it asap...
              • TIGT
                I just checked it out... and in m² and ft² it works just fine for me ??
                What units/precision do you have set for your Model Info > Units > Area ?
                Can you attach a simple SKP that's causing you issues ?
                • B
                  Ben Ritter
                  Architectural Units, accuracy at 1/16".
                  Attached is the file. Original circle about 78sf. Larger Circle was supposed to be 100 sf.
                  Scale Test.skp
                  • B
                    Ben Ritter
                    Perhaps it's the way the units are entered?
                    • TIGT
                      When I try your SKP I get the wrong result too !
                      When I test it myself it was OK...
                      BUT now if I test it with a circle around the face it does scale oddly.
                      If I explode the circle first it works OK...
                      So something is adrift...
                      It's because the scaling transformation affects the face's vertices, and when it's a simple outline they get process individually, but when it's a circle they get processed repeatedly and so the scaling is then way off !
                      Leave it with me for a while why I invent another transformation method !!
                      • B
                        Ben Ritter
                        TIG,
                        OK, thanks.
                        I get the same result if I explode the curve or polygon. Simple non-curve lines around a face work fine.
                        • TIGT
                          Here's v2.0
                          I've fixed it to cope with all face perimeters - i.e. circles etc...
                          Download the RBZ and install...
                          Please test it and report back...
                          • B
                            Ben Ritter
                            TIG, Great. No problems. Thanks so much for your work on the extension. 👍 👍
