    PNG not transparent in render.
    renderpluginsextensions
    9 Posts 5 Posters 5.9k Views 5 Watching
      supersparkk
      Hi folks.
      I have a question to a problem you've probably encountered before, but somehow I can't find any solution when I google it. The problem is, I get a black background on my PNG's when I render my project.
      I hope one of you can tell me what I do wrong.
      My plan is to make a plastic wall with a logo on it.
      Here's what I do.
      1. I start out by creating an infinite plane.
      2. Then I create a box from a rectangle and push/pull.
      3. I select it and make it into a group.
      4. While highlighted, I go into the VRay asset editor and choosing the "Plastic Simple Shiny Black", changing it to another color in diffuse, under the VRayBRDF section, and then apply the material to the selection.
      5. Then I import a PNG with transparent background onto the face of the box.
      6. After that I go for the render.
      Any ideas what I do wrong?
      Kind regards
      Paul
        rspierenburg
        Are you importing the PNG as a Texture or as an Image? Do you have a picture of the outcome?
          supersparkk
          I import the png as an image, because if I choose texture, it will fill out the entire surface.
          This is what it looks like before and after render.
          • L Online
            Can you attach the SKP file mate?
              supersparkk
              Sure.
              Box.zip
              • L Online
                Always best to post model in a previous version say 2015 to be safe
                  supersparkk
                  !!Closing my post, since I've found another way to render my projects.!!
                  • HornOxxH Offline
                    HornOxx
                    ... before you close completely πŸ˜‰ - which way did you find?
                    never trust a skinny cook
                      rezvan23
                      I just exploded the logo (so it won't be an image), then moved it 0.1mm away from the box.
