    [Plugin] Universal Importer - v1.2.7 - 14 Nov. 2026
    459 Posts 112 Posters 644.3k Views 113 Watching
    • samuel_tS
      samuel_t
      @malditobill said:
      Hi. Do I have to install Assimp library and MeshLab software before Universal Importer? Ive just installed only Universal Importer and in the tool bar only get the reduce poligons icons.
      Hi. No. Assimp library and MeshLab software are bundled with Universal Importer plugin. SketchUp toolbar only contains shortcut to Poly reducer... In SketchUp menu, use "File > Import with Universal Importer...".
      • R
        rspierenburg
        I'm trying to import an OBJ. I want to keep the existing model scale but the plugin keeps asking for the height of the model. Is there a way to ignore that?
        • samuel_tS
          samuel_t
          Hello. You can't ignore that.
          • L
            Lacee
            Unable to reduce a 6,000,000 poly SU2020 file / also unable to import OBJ source file for same #2
            Posted in GitHub.
            • K
              Kolarik
              1. Can you explain, how size of imported object is calculated? I am not able to import objects in correct size. See attached example - block 10x20x30mm
                Original block
                It was exported to STL, and imported back by Universal Importer.
                Height set to 1 cm
                Size settings
                no texture, no reduction.
                Result :
                Result of import
              I do not know, what I am doing bad....
              1. I am using milimetres as default in Sketchup - if the sizing rules would work, can it be changed into mm instaed of cm?
              • samuel_tS
                samuel_t
                Posted in GitHub.
                Hello Lacee. I just answered you at GitHub πŸ˜‰
                • E
                  Einstein
                  Hello,
                  Would it be possible to support importing loose edges from Blender? When a mesh contains faces, it imports properly but if there are only edges, they don't get imported.
                  It would also be cool if separate Blender objects would be imported to separate SketchUp groups. But I'm aware this can be a lot of work to code.
                  • samuel_tS
                    samuel_t
                    Technically, sizing algorithm is a hack. Since in most cases, by default, imported object is oversized: plugin scales down this object to height set by user. This hack works pretty well with "tall" objects.
                    Maybe if I ask user for a height in mm instead of cm, size of imported model will be more accurate...
                    • samuel_tS
                      samuel_t
                      @einstein said:
                      Hello,
                      Hello. No. You can see Universal Importer plugin for SketchUp as an Assimp script. This means that, in most cases, if Assimp doesn't support a feature: Universal Importer plugin doesn't support this feature.
                      • K
                        Kolarik
                        I would prefer it, either as default or at least as option.
                        • E
                          Einstein
                          Hello,
                          I have a problem with importing Blend files. There is a model in Blender containing one object with all faces touching each other, so the object is "water-tight", "3D-printable" and there are no "border edges" (every edge is connected to two faces).
                          When I import it to SketchUp, some faces stay connected but some disconnect, leaving doubled vertices living nearby but not touching each other. This basically makes a broken mesh.
                          Can something be done with this issue - either manually, or within the plugin?
                          I tried exporting from Blender to OBJ, then to SketchUp. It fixes the issue if I use ThomThom's QFT OBJ importer but introduces another issue - missing some faces.
                          The BLEND model is in the ZIP archive because SketchUcation won't let me post BLEND files.
                          not all faces stick together.skp
                          CruiseShip old big.zip
                          • B
                            brettmahon01
                            Hi, this plugin sounds amazing! i installed but i keep getting error message?
                            Universal Importer Error: Command failed: "/Users/brettmahon/Library/Application Support/SketchUp 2019/SketchUp/Plugins/universal_importer/Assimp/Mac/assimp" info "/Users/brettmahon/.UniversalImporter/tmp/import.obj" > "/Users/brettmahon/.UniversalImporter/tmp/assimp.nfo"
                            /Users/brettmahon/Library/Application Support/SketchUp 2019/SketchUp/Plugins/universal_importer/assimp.rb:166:in `get_texture_refs'
                            Universal Importer Version: 1.1.5
                            • samuel_tS
                              samuel_t
                              @einstein said:
                              Hello,
                              Hello. I don't know Blender enough to help you 😞
                              • samuel_tS
                                samuel_t
                                Hi, you have probably a file permission issue. Open a Terminal in your Mac then run these commands:
                                chmod +x "/Users/brettmahon/Library/Application Support/SketchUp 2019/SketchUp/Plugins/universal_importer/Assimp/Mac/assimp"
                                chmod +x "/Users/brettmahon/Library/Application Support/SketchUp 2019/SketchUp/Plugins/universal_importer/MeshLab/Mac/MacOS/meshlabserver"
                                Then reopen SketchUp.
                                • N
                                  NC3D
                                  Samuel
                                  Seems like a great plug-in, thanks for sharing this!
                                  We have an fbx we are trying to bring in but we are not sure how to get it to be placed exactly where we want it and at the right scale. I think we could find the right scale factor to get it right but unfortunately I can not type in an accurate enough number (only integers allowed) into the dialogue box.
                                  Is there a better way or different way we could have our model drop in more accurately?
                                  Kind Regards,
                                  Greg Hamilton
                                  • samuel_tS
                                    samuel_t
                                    @nc3d said:
                                    Samuel
                                    Kind Regards,
                                    Greg Hamilton
                                    Hello, There's no solution for the moment. Maybe I'll publish a more accurate plugin version in the future. Best regards.
                                    • N
                                      Noire0891
                                      Sketchup 2016 will be implemented?
                                      • samuel_tS
                                        samuel_t
                                        I don't think so.
                                        • X
                                          xinhengxie
                                          Your software is very useful!! Thanks a million!! BTW, I don't know if you have thought of adding an function that it can import OSGB file format, it would be cool!!
                                          Merry Christmas!!!!!!
                                          • samuel_tS
                                            samuel_t
                                            1.1.6 version improves scaling accuracy during import and fixes file permissions issue on MacOS.
                                            Download latest Universal Importer plugin from SketchUcation PluginStore.
                                            Happy new year!
                                            • 10
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 22
                                            • 23
                                            • 12 / 23
