    [Plugin] Universal Importer - v1.2.6 - 30 July 2024
    452 Posts 111 Posters 596.5k Views 112 Watching
    • samuel_tS Offline
      samuel_t
      @einstein said:
      Hello,
      Would it be possible to support importing loose edges from Blender? When a mesh contains faces, it imports properly but if there are only edges, they don't get imported.
      It would also be cool if separate Blender objects would be imported to separate SketchUp groups. But I'm aware this can be a lot of work to code.
      Hello. No. You can see Universal Importer plugin for SketchUp as an Assimp script. This means that, in most cases, if Assimp doesn't support a feature: Universal Importer plugin doesn't support this feature.
        Kolarik
        @samuel_t said:
        Maybe if I ask user for a height in mm instead of cm, size of imported model will be more accurate...
        I would prefer it, either as default or at least as option.
        • E Offline
          Einstein
          Hello,
          I have a problem with importing Blend files. There is a model in Blender containing one object with all faces touching each other, so the object is "water-tight", "3D-printable" and there are no "border edges" (every edge is connected to two faces).
          When I import it to SketchUp, some faces stay connected but some disconnect, leaving doubled vertices living nearby but not touching each other. This basically makes a broken mesh.
          Can something be done with this issue - either manually, or within the plugin?
          I tried exporting from Blender to OBJ, then to SketchUp. It fixes the issue if I use ThomThom's QFT OBJ importer but introduces another issue - missing some faces.
          The BLEND model is in the ZIP archive because SketchUcation won't let me post BLEND files.
          not all faces stick together.skp
          CruiseShip old big.zip
            brettmahon01
            Hi, this plugin sounds amazing! i installed but i keep getting error message?
            Universal Importer Error: Command failed: "/Users/brettmahon/Library/Application Support/SketchUp 2019/SketchUp/Plugins/universal_importer/Assimp/Mac/assimp" info "/Users/brettmahon/.UniversalImporter/tmp/import.obj" > "/Users/brettmahon/.UniversalImporter/tmp/assimp.nfo"
            /Users/brettmahon/Library/Application Support/SketchUp 2019/SketchUp/Plugins/universal_importer/assimp.rb:166:in `get_texture_refs'
            Universal Importer Version: 1.1.5
            • samuel_tS Offline
              samuel_t
              @einstein said:
              Hello,
              Hello. I don't know Blender enough to help you 😞
              • samuel_tS Offline
                samuel_t
                Hi, you have probably a file permission issue. Open a Terminal in your Mac then run these commands:
                chmod +x "/Users/brettmahon/Library/Application Support/SketchUp 2019/SketchUp/Plugins/universal_importer/Assimp/Mac/assimp"
                chmod +x "/Users/brettmahon/Library/Application Support/SketchUp 2019/SketchUp/Plugins/universal_importer/MeshLab/Mac/MacOS/meshlabserver"
                Then reopen SketchUp.
                • N Offline
                  NC3D
                  Samuel
                  Seems like a great plug-in, thanks for sharing this!
                  We have an fbx we are trying to bring in but we are not sure how to get it to be placed exactly where we want it and at the right scale. I think we could find the right scale factor to get it right but unfortunately I can not type in an accurate enough number (only integers allowed) into the dialogue box.
                  Is there a better way or different way we could have our model drop in more accurately?
                  Kind Regards,
                  Greg Hamilton
                  • samuel_tS Offline
                    samuel_t
                    @nc3d said:
                    Samuel
                    Kind Regards,
                    Greg Hamilton
                    Hello, There's no solution for the moment. Maybe I'll publish a more accurate plugin version in the future. Best regards.
                    • N Offline
                      Noire0891
                      Sketchup 2016 will be implemented?
                      • samuel_tS Offline
                        samuel_t
                        I don't think so.
                        • X Offline
                          xinhengxie
                          Your software is very useful!! Thanks a million!! BTW, I don't know if you have thought of adding an function that it can import OSGB file format, it would be cool!!
                          Merry Christmas!!!!!!
                          • samuel_tS Offline
                            samuel_t
                            1.1.6 version improves scaling accuracy during import and fixes file permissions issue on MacOS.
                            Download latest Universal Importer plugin from SketchUcation PluginStore.
                            Happy new year!
                              azgcz
                              @samuel_t said:
                              @rspierenburg said:
                              I'm trying to import an OBJ. I want to keep the existing model scale but the plugin keeps asking for the height of the model. Is there a way to ignore that?
                              Hello. You can't ignore that.
                              I would like to add this feature"cancel /height of the model/ will keep the existing model scale"although I can do it the other way around:
                              SU toolbar--Windows--Administration panel--Component--Homepage--Select import component you want-Deploy this component which keep the existing model scale:)
                              Add the feature will be more convenient for me, thanks!
                                dolfek
                                Hello,
                                please, where is a problem? I have sketchup 2021.
                                Thank you for your answer.
                                • samuel_tS Offline
                                  samuel_t
                                  @dolfek said:
                                  Hello,
                                  Hello.
                                  It seems you are trying to import an .obj file that references a non-existent .mtl file. Can you please share with us these .obj and .mtl files?
                                    luiz_m11r
                                    Hi, Samuel! I'm very exciting to start using this plugin. I keep getting this error message though. Already tryied installing the Microsoft Visual C++ library but it still doesnt work. How can i fix it?
                                    • samuel_tS Offline
                                      samuel_t
                                      Hi Luiz. Your problem is maybe related to glTF... Can you please share with us .gltf file and textures you are trying to import?
                                        catchen5890
                                        I have a problem while importing step in sketchup 2020
                                        [img]file:///C:/Users/Administrator/Downloads/fail%20report.jpg[/img]
                                        • samuel_tS Offline
                                          samuel_t
                                          Compatibility with STEP models isn't very good. Unfortunately, I don't have a solution for the moment.
                                          • MikeG73M Offline
                                            MikeG73
                                            Hello Samuel,
                                            I installed your latest release on sketchupmake2017 and can not use it as it is unsigned, please update your extension with a signed version. 😎
                                            Cheers Mate!
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 22
                                            • 23
                                            • 12 / 23
