    [Plugin] Universal Importer - v1.2.6 - 30 July 2024
    452 Posts 111 Posters 596.5k Views 112 Watching
      Kolarik
      1. Can you explain, how size of imported object is calculated? I am not able to import objects in correct size. See attached example - block 10x20x30mm
        Original block
        It was exported to STL, and imported back by Universal Importer.
        Height set to 1 cm
        Size settings
        no texture, no reduction.
        Result :
        Result of import
      I do not know, what I am doing bad....
      1. I am using milimetres as default in Sketchup - if the sizing rules would work, can it be changed into mm instaed of cm?
      • samuel_tS Offline
        samuel_t
        @lacee said:
        Unable to reduce a 6,000,000 poly SU2020 file / also unable to import OBJ source file for same #2
        Posted in GitHub.
        Hello Lacee. I just answered you at GitHub πŸ˜‰
        • E Offline
          Einstein
          Hello,
          Would it be possible to support importing loose edges from Blender? When a mesh contains faces, it imports properly but if there are only edges, they don't get imported.
          It would also be cool if separate Blender objects would be imported to separate SketchUp groups. But I'm aware this can be a lot of work to code.
          • samuel_tS Offline
            samuel_t
            Technically, sizing algorithm is a hack. Since in most cases, by default, imported object is oversized: plugin scales down this object to height set by user. This hack works pretty well with "tall" objects.
            Maybe if I ask user for a height in mm instead of cm, size of imported model will be more accurate...
            • samuel_tS Offline
              samuel_t
              @einstein said:
              Hello,
              Hello. No. You can see Universal Importer plugin for SketchUp as an Assimp script. This means that, in most cases, if Assimp doesn't support a feature: Universal Importer plugin doesn't support this feature.
                Kolarik
                I would prefer it, either as default or at least as option.
                • E Offline
                  Einstein
                  Hello,
                  I have a problem with importing Blend files. There is a model in Blender containing one object with all faces touching each other, so the object is "water-tight", "3D-printable" and there are no "border edges" (every edge is connected to two faces).
                  When I import it to SketchUp, some faces stay connected but some disconnect, leaving doubled vertices living nearby but not touching each other. This basically makes a broken mesh.
                  Can something be done with this issue - either manually, or within the plugin?
                  I tried exporting from Blender to OBJ, then to SketchUp. It fixes the issue if I use ThomThom's QFT OBJ importer but introduces another issue - missing some faces.
                  The BLEND model is in the ZIP archive because SketchUcation won't let me post BLEND files.
                  not all faces stick together.skp
                  CruiseShip old big.zip
                    brettmahon01
                    Hi, this plugin sounds amazing! i installed but i keep getting error message?
                    Universal Importer Error: Command failed: "/Users/brettmahon/Library/Application Support/SketchUp 2019/SketchUp/Plugins/universal_importer/Assimp/Mac/assimp" info "/Users/brettmahon/.UniversalImporter/tmp/import.obj" > "/Users/brettmahon/.UniversalImporter/tmp/assimp.nfo"
                    /Users/brettmahon/Library/Application Support/SketchUp 2019/SketchUp/Plugins/universal_importer/assimp.rb:166:in `get_texture_refs'
                    Universal Importer Version: 1.1.5
                    • samuel_tS Offline
                      samuel_t
                      @einstein said:
                      Hello,
                      Hello. I don't know Blender enough to help you 😞
                      • samuel_tS Offline
                        samuel_t
                        Hi, you have probably a file permission issue. Open a Terminal in your Mac then run these commands:
                        chmod +x "/Users/brettmahon/Library/Application Support/SketchUp 2019/SketchUp/Plugins/universal_importer/Assimp/Mac/assimp"
                        chmod +x "/Users/brettmahon/Library/Application Support/SketchUp 2019/SketchUp/Plugins/universal_importer/MeshLab/Mac/MacOS/meshlabserver"
                        Then reopen SketchUp.
                        • N Offline
                          NC3D
                          Samuel
                          Seems like a great plug-in, thanks for sharing this!
                          We have an fbx we are trying to bring in but we are not sure how to get it to be placed exactly where we want it and at the right scale. I think we could find the right scale factor to get it right but unfortunately I can not type in an accurate enough number (only integers allowed) into the dialogue box.
                          Is there a better way or different way we could have our model drop in more accurately?
                          Kind Regards,
                          Greg Hamilton
                          • samuel_tS Offline
                            samuel_t
                            @nc3d said:
                            Samuel
                            Kind Regards,
                            Greg Hamilton
                            Hello, There's no solution for the moment. Maybe I'll publish a more accurate plugin version in the future. Best regards.
                            • N Offline
                              Noire0891
                              Sketchup 2016 will be implemented?
                              • samuel_tS Offline
                                samuel_t
                                I don't think so.
                                • X Offline
                                  xinhengxie
                                  Your software is very useful!! Thanks a million!! BTW, I don't know if you have thought of adding an function that it can import OSGB file format, it would be cool!!
                                  Merry Christmas!!!!!!
                                  • samuel_tS Offline
                                    samuel_t
                                    1.1.6 version improves scaling accuracy during import and fixes file permissions issue on MacOS.
                                    Download latest Universal Importer plugin from SketchUcation PluginStore.
                                    Happy new year!
                                      azgcz
                                      @samuel_t said:
                                      @rspierenburg said:
                                      I'm trying to import an OBJ. I want to keep the existing model scale but the plugin keeps asking for the height of the model. Is there a way to ignore that?
                                      Hello. You can't ignore that.
                                      I would like to add this feature"cancel /height of the model/ will keep the existing model scale"although I can do it the other way around:
                                      SU toolbar--Windows--Administration panel--Component--Homepage--Select import component you want-Deploy this component which keep the existing model scale:)
                                      Add the feature will be more convenient for me, thanks!
                                        dolfek
                                        Hello,
                                        please, where is a problem? I have sketchup 2021.
                                        Thank you for your answer.
                                        • samuel_tS Offline
                                          samuel_t
                                          @dolfek said:
                                          Hello,
                                          Hello.
                                          It seems you are trying to import an .obj file that references a non-existent .mtl file. Can you please share with us these .obj and .mtl files?
                                            luiz_m11r
                                            Hi, Samuel! I'm very exciting to start using this plugin. I keep getting this error message though. Already tryied installing the Microsoft Visual C++ library but it still doesnt work. How can i fix it?
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 22
                                            • 23
                                            • 12 / 23
