    Possible for multi delete of these within a few click?
    4 Posts 2 Posters 9.3k Views 2 Watching
    • sketchartist023S Offline
      sketchartist023
      I was wondering if it is possible in sketchup, either natively or through a plugin of sort, to delete multiple (sometimes more than 40) internal faces of an isocontour rather than inside of a 3d model.
      The faces that are not highlighted, for example, around a larger face with detail. Kind-of "secondary" internal faces if properly put.
      Maybe even more than secondary as well, idk. Just thought of this today to try to see if I can speed of a process, instead of highlighting all then delete, or individual, etc.
      Thank you πŸ˜„
      Here is a snapshot of an example I would like to test it on:
      secondary internal not primary internal
      • BoxB Offline
        You can do Triple click to select all then shift double click to deselect the face and all it's edges that you want to keep and delete the rest.
        A simple example.
          sketchartist023
          That sounds very workable, thank you πŸ˜„ Ill try it now and I figured it could be done internal so should work πŸ˜„ Thanks again!
            sketchartist023
            It worked quite well thank you very much. I kne the +/- was good for both plus and minus somehow πŸ˜›
            Hope all is well!
            selected
            removed
