    Possible for multi delete of these within a few click?
    4 Posts 2 Posters 9.6k Views 2 Watching
    • sketchartist023S
      sketchartist023
      I was wondering if it is possible in sketchup, either natively or through a plugin of sort, to delete multiple (sometimes more than 40) internal faces of an isocontour rather than inside of a 3d model.
      The faces that are not highlighted, for example, around a larger face with detail. Kind-of "secondary" internal faces if properly put.
      Maybe even more than secondary as well, idk. Just thought of this today to try to see if I can speed of a process, instead of highlighting all then delete, or individual, etc.
      Thank you πŸ˜„
      Here is a snapshot of an example I would like to test it on:
      secondary internal not primary internal
      • BoxB
        You can do Triple click to select all then shift double click to deselect the face and all it's edges that you want to keep and delete the rest.
        A simple example.
        • sketchartist023S
          sketchartist023
          That sounds very workable, thank you πŸ˜„ Ill try it now and I figured it could be done internal so should work πŸ˜„ Thanks again!
          • sketchartist023S
            sketchartist023
            It worked quite well thank you very much. I kne the +/- was good for both plus and minus somehow πŸ˜›
            Hope all is well!
            selected
            removed
