    [Plugin] FredoGuides - v2.9a - 19 Dec 25
    55 Posts 17 Posters 62.0k Views 17 Watching
    • fredo6F Offline
      fredo6
      @penumbra said:
      I am experiencing a strange behaviour with the plugin. it appears to make copies of the protected guides every time i use the "delete all guides" command. There are thousands of copies of the Fredoguides in the outliner appear. i'll [ost the file later.
      If you can reproduce it, I'll be interested in the file.
      Also, if you can leave the Ruby console opened when deleting guides...
      • fredo6F Offline
        fredo6
        NEW RELEASE: FredoGuides v1.3a - 21 May 20
        Requirement: LibFredo6 9.5k
        FredoGuides v1.3a extends the validity.
        **Home Page of FredoGuides** for information and Download.
        Main post of this FredoGuides thread.
        • zivotinjaZ Offline
          zivotinja
          I have uninstalled fredoguides since it is causing a problem with the operation - you need to upgrade fredo guide since the license has expired (???!) However the error still appears. And I have checked the plugin folder it is not there. However, the icon bar appears in the SK2019. What to do??
          Thank you
          • fredo6F Offline
            fredo6
            To uninstall, please delete both the Fredo6_FredoGuides.rb file and the Fredo6_FredoGuides subfolder.
            Did you try however to upgrade to the new version?
            Fredo
              zivotinja
              So all elements are removed from the plugins folder. However the toolbar still shows. ??! 🤢 😮
                zivotinja
                FYI
                First Image
                Second Image
                  zivotinja
                  I have uninstalled and restarted. However, the toolbar and error message still appear
                    zivotinja
                    Error Message. I cannot use right mouse button any more
                    error
                    • fredo6F Offline
                      fredo6
                      Since you restarted Sketchup, there must be another place where Sketchup take FredoGuides from.
                      Otherwise, it would be magic....
                      • fredo6F Offline
                        fredo6
                        NEW RELEASE: FredoGuides v1.4a - 25 May 20
                        Requirements
                        • LibFredo6: v10.5a
                        FredoGuides v1.4a is a maintenance release for bug fixing and cosmetic adjustments for Mac
                        • fredo6F Offline
                          fredo6
                          NEW RELEASE: FredoGuides v1.5a - 19 Aug 20
                          Requirements
                          • LibFredo6: v11.0a
                          FredoGuides v1.5a is a maintenance release for bug fixing, cosmetic adjustments and extension of validity
                          • SJS66S Offline
                            SJS66
                            I just posted about FredoGuides not updating in SU but I also have to say, this topic has to have one of the most confusing posts I've ever seen. Talk about taking around in circles. I'll have to search 'my posts' to find where I just posted, or maybe I just need a kit kat....lol.
                              You started a new thread here: https://sketchucation.com/forums/viewtopic.php?f=80&t=72568&p=660727#p660727 You didn't put your post in this thread.
                              Do have the latest release of LibFredo6?
                              • fredo6F Offline
                                fredo6
                                NEW RELEASE: FredoGuides v1.6a - 20 Nov 20
                                Requirements
                                • LibFredo6: v11.0a
                                FredoGuides v1.5a is a maintenance release for extension of validity
                                • fredo6F Offline
                                  fredo6
                                  NEW RELEASE: FredoGuides v1.7a - 06 Jan 21
                                  Requirements
                                  • LibFredo6: v11.0a
                                  FredoGuides v1.7a is a maintenance release for extension of validity
                                  • fredo6F Offline
                                    fredo6
                                    NEW RELEASE: FredoGuides v1.8a - 27 Jan 21
                                    Requirements
                                    • LibFredo6: v11.0a
                                    FredoGuides v1.8a is a maintenance release for extension of validity
                                    • SJS66S Offline
                                      SJS66
                                      I'm getting an error with FredoGuides v1.8a. If I try to use the toolbar, SU 2021 keeps telling me it's out of date but Fredo6 Plugins Update Check says everything is up to date!
                                      I uninstalled then downloaded the latest version & manually installed using Extension Manager but still getting same message.
                                      I swear it was working fine the other day.
                                      • fredo6F Offline
                                        fredo6
                                        NEW RELEASE: FredoGuides v1.9a - 01 Apr 21
                                        Requirements
                                        • LibFredo6: v11.0a
                                        FredoGuides v1.9a is a maintenance release for extension of validity
                                        • SJS66S Offline
                                          SJS66
                                          Thanks for the update Fredo. V1.9a working like a charm. Awesome. I did notice still only compatible to 2020 on download post description though. Could be updated too maybe?
                                          • fredo6F Offline
                                            fredo6
                                            NEW RELEASE: FredoGuides v2.0a - 24 Apr 21
                                            Requirements
                                            • LibFredo6: v11.0a
                                            FredoGuides v2.0a is a technical release for performance of contextual selection menu
                                            • 2 / 3
