    Octagon Hammerhead Bevel
    13 Posts 7 Posters 2.0k Views 7 Watching
      Jersey22651
      I designed a small sledge hammer to be made of brass and used for display.
      I actually made one about almost 50 years ago and decided to craft one for my grandson.
      The 45-degree bevel on each end of the original hammer was machined on a lathe.
      In Sketchup I beveled the octagon on the ends of the hammer using Fredo6 Round Corner and, as seen in the drawing below, the face of the hammer is also octagonal.
      I tried to make the face at the end of the bevel round while keeping the octagon at the top of the bevel without success.
      Does anyone have any idea if this can be done?
      Any help will be appreciated.
      Don
        Hammer2.pngHi, I would not have used the round corner tool I would have used "follow me" tool
        If you rounded off the octagonal edge a bit it would also work and be a little more real
        Cheers
        • BoxB Offline
          Something like this.
            Jersey22651
            Referring back to my hammer pic, my goal is to maintain the sharp edge on the outer or larger octagon, the true 45-degree angle descending into a circle on the face. Reiterating that I want the bevel to look as if it were cut on a lathe.
            It is fine if this cannot be exactly done in sketchup.
            I just need to know if it is possible and if so, how.
              TBoy
              Use Fredo6_CurviLoft.
              In the above picture circle is inscribed and 45 degree will be at points where circle touch the octagon. 45 degree angle will vary according to distance of corresponding points from octagon to circle.
                Maybe something close to this? Nothing but native tools.
                  I modeled basically what TBoy shows with his bolt head image. I modeled it the same way I would model that bolt head, too.
                    TBoy
                    Here bevel angle is constant but octagon is not with straight lines.
                    DaveR proposal is to make very small second bevel to convert small octagon to circle.
                      Jersey22651
                      Thank you all for your help.
                      Dave R: I have no experience modeling a bolt head as shown in your picture. That is exactly what I want the hammerhead to look like.
                      Would you mind providing information on how to do this?
                      Or, refer me to a tutorial somewhere?
                      • BoxB Offline
                        One option is to use solid tools to use a cutter that you subtract from the octagon.
                          Sorry. I got called away. I did something similar to what Box shows with the addition of a chamfer added to the head first. Offset to define the limits chamfer, Move with Auto-Fold to pull the face out. Then a dome shape intersected and the waste removed.
                          Click on the picture if it doesn't move on its own.
                          You can change the result to be like the head of the bolt by omitting the chamfer and you can adjust the location of the dome.
                            ...or take a look to the Geodesic Taffgosh collection! πŸ˜‰
                            Or the McMaster-Carr collection...
                              Interesting links but the McMaster-Carr collection appears not to have a CAD relevance.
