Cant find Animator in my UI
I just installed Fredos Animator v.2.5a. I have the latest Libfredo library and all other Fredo plugins work great. I have tried many ways to install it. Manually directly into plugins folder and using Skethcucation store etc. I cant see it under Extensions, Tools or any other menus (do see other Fredo stuff though).
I dont see it under Sketchucation extension manager.
I dont see it when right clicking toolbars area to select plugins (yellow drop-bar thing with check boxes).
I only see it when I open Sketchucation plugins manager window and it shows as installed and enabled.Where is it? How can I launch it. What am I missing...or have I gone blind?
Any help much appreciated.
Borkur -
Have you looked here
Usage: Tools > Fredo6 Collection > AnimatorDid you click past this popup message when you installed it without reading it.
having the same problem on Mac
You need the Extension and the latest Fredo Lib both to be installed.
Then you need to restart SketchUp completely, to ensure everything is properly synced.Also read the Extension's usage guidance - to make sure you understand how its menu is accessed, and also any Toolbar details etc...
Register LoginAdvertisement
