    Sports car.
    14 Posts 4 Posters 17.3k Views 4 Watching
      No render yet, just the Sketchup export. Looking to get the surfaces right at the moment.
      No textures.
      • Bryan KB Offline
        That's looking really good!
          Thanks Bryan.
          • HornOxxH Offline
            HornOxx
            wunderbar πŸ‘ πŸ‘ also without rendering prima already πŸ˜„
            never trust a skinny cook
              Thanks very much, some changes made some more to come.
                Altered a few things because the elements became unstable. Harlequin to show different area's altered during the cycles.
                Not a render per se, more a check on surfaces.
                Harlequin.
                • Bryan KB Offline
                  Don't stop now!
                  • HornOxxH Offline
                    HornOxx
                    @bryan k said:
                    Don't stop now!
                    Yes - besides I liked this "frog eye lamp" idea on the motor hood and I hope that this characteristic (from the earlyer pictur above) will remain somehow... πŸ˜‰
                      I haven't stopped, I had a slight developmental issue, or brain fade. Lots of stuff happening at my gaff so will get back to this model soon.
                      • Bryan KB Offline
                        I can relate.
                        Looking forward to updates. πŸ‘
                          Corrupt file, complete bleeping failure. Gutted.
                          • BoxB Offline
                            @mike amos said:
                            Corrupt file,
                            To where do you save your files?
                              I save to a specific folder in my second hdd. Luckily I have found an older version. I save files with different file names until the succeeding file is good enough then gradually delete the older versions.
                              • BoxB Offline
                                Is your second HDD built in or is it networked or connected in some other possibly intermittent connection.
                                The most common reason for corrupt files is saving your file to anywhere that isn't totally local, even a local folder that syncs to dropbox/one drive/network etc has the potential to kill your file.
                                Basically a file can try to sync while it is trying to save, causes a clash and your file is effectively gone.
                                So make sure you save locally and sync/backup manually.
